can't get zuki back into 2WD - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-05-2002, 02:21 PM
can\'t get zuki back into 2WD
HELP!!!
I haven't used 4WD for a few years but decided to shift into it while standing still in my drive. The hubs weren't locked but I didn't move. When I shifted it into 4WD the dash indicator lit up and everything seamed normal, however, when I shifted it back to 2WD it stuck in neutral and refuses to budge............
My neighbor's just did the same thing........
Your thoughts are truly appreciated.
post #2 of (permalink) Old 04-05-2002, 02:30 PM
Re: can\'t get zuki back into 2WD
sounds like a tranny sheet is needed to me.....
post #3 of (permalink) Old 04-05-2002, 02:31 PM
Pull out the shifter to the t/c and get you a big screwdriver then use that to line up the shift rails. I had an old sammy that used to do that occasionally.
JeepinDoberman is offline
post #4 of (permalink) Old 04-05-2002, 02:50 PM
Urban_Zuk
Definately sounds like a carroded tcase sheet. Here is a good website that helped me imensly. Easy install and fixed mine in less than an hour. http://www.off-road.com/suzuki/reviews/rrsheet.htm
post #5 of (permalink) Old 04-05-2002, 03:53 PM
here is a picture of the shifter with the sheet that they are talking about at the bottom
rich_d is offline
post #6 of (permalink) Old 04-05-2002, 10:19 PM
Great pic, Rich. The "sheet" that everyone is referring to is nothing more than a cup that the shifter ball rides upon. What happens is that they get worn, and allow the tip of the shifter to drop down too far, getting the shift forks out of sync. Remove the four boot bolts , and the knob. There is a wire ring on top of the tcase shifter tower that holds the rubber tower boot on. Squeeze the two ends of the ring to remove it and the boot. There is a ring retainer that keeps the shifter ball seated in the tower. If you use two large long screwdrivers , you can push down and rotate it 1/4 turn to unlock it . Once it's unlocked, you can remove the shifter stick.Just pull it straight up , and out of the way . Under that shifter ball is the offending sheet . If it's worn or torn at all , it needs to be replaced . If you look at the two shift rails , there is a half square cutout in the shafts . In the nuetral position , they should be lined up to form a square in the middle . If they are out of line, the sheet has allowed them to get out of sync. Just use one of those big screwdrivers to put them back in line, and replace the entire shifter assembly . Make sure the wire retainer fits into the groove to keep water and dirt out of the tcase . Have fun..
Sarge
Sarge is offline
post #7 of (permalink) Old 04-16-2002, 09:22 PM
Thanks for the help, I was able to fix my neighbors as well for only $15 bucks!!!
post #8 of (permalink) Old 04-16-2002, 09:57 PM
ackerdackerly's Avatar
In case someone looks at this thread in the future, here's an installation tip:
use one of those adjustable tightening tools for 4" angle grinders (the one you buy when you lose the first one...) to tighten the spring-loaded metal cup that holds the transfer case shifter in place.
This tool has two pins sticking out that, when properly spaced, make snapping the cup into place a, well, a snap!
Unfortunately, this method works best when the case has been removed. Use Sarge's screwdriver method if you are working with an installed unit.
ackerdackerly is offline
post #9 of (permalink) Old 04-17-2002, 05:59 PM
same thing happened to me, got some new t/c "sheets" or "ring" if you need a new please let me
know. I have them on my web site. Thanks
Rogue Suzuki
post #10 of (permalink) Old 04-17-2002, 06:07 PM
shoezuki
Ack,
A nice set of needle nose pliers work too (open jaw the same diameter as the slots, insert and twist) Just thought I'd add my .0002 cents (yes the decimal place is correct)
