Timing belt change - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-04-2002, 09:33 PM
Timing belt change
I changed the belt but I think I got the belt to tight. When I started it. the engine warmed up and the timing belt started to make noise. Does anybody have info on the tension needed?
post #2 of (permalink) Old 04-04-2002, 09:50 PM
MrSurly's Avatar
Re: Timing belt change
Yes. The tensioning procedure is given in the service manuals. You loosen the tensioner bolt and nut, turn the crankshaft two full turns clockwise with a socket on the center bolt, then retighten the tensioner nut and bolt. HTH
MrSurly is offline
post #3 of (permalink) Old 04-04-2002, 10:02 PM
I did that but it seems that the belt was to loose does it tighten up during operation .If I got the belt off one tooth will it still run.Or just back fire?
post #4 of (permalink) Old 04-04-2002, 10:25 PM
MrSurly's Avatar
I've never run an engine with the belt one tooth off, so I don't know if they will run that way or not. And no, a belt won't tighten up during use. But they don't have a lot of tension on them when the tensioner is adjusted correctly. If they did, it would wear out the tensioner and the belt. HTH
MrSurly is offline
post #5 of (permalink) Old 04-05-2002, 12:40 AM
They will run, there will just be a hesitation when you hit the gas, minor one. there is a brand of belt that is known to be real tight, can't think of the name though......
Samurai202 is offline
post #6 of (permalink) Old 04-05-2002, 10:07 AM
Yes, it will run one tooth off. I found that my 87 was one tooth advance. it was like this when I bought it. Run great up to 3000 rpm, but after that it was a dog. When the other barrel of the carb came on it would bog bad, Reset the cam and crank and now I am happy with it.
ka4yqi is offline
