weber carb - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-27-2002, 06:42 PM
weber carb
ABOUT A WEEK AGO MY SAMI STARTED RUNNING BAD AND MISSING REALLY BAD. I HAVE REPLACED THE DIST. CAP, PLUGS, WIRE, TIMING BELT, FUEL FILTER, AND THEN INSTALLED A WEBER BECAUSE MY CARB HAS BEEN BURNING REALLY RICH. AFTER DOING ALL OF THAT IT WILL IDLE BUT HAS NO POWER AND WHEN I TAKE THE BREATHER OFF IT IS COVERED WITH FUEL. WHAT NEXT
post #2 of (permalink) Old 02-27-2002, 07:23 PM
Re: weber carb
Somethin's up with your fuel line, Are you sure you got everything installed correctly?
1987 Samurai JX
2002 Wrangler TJ
I'd sleep in my rigs all night before I'd let a Ford/Chevy Pull me out.
Samurai202 is offline
post #3 of (permalink) Old 02-27-2002, 09:05 PM
Re: weber carb
THE FUEL LINE LOOKS TO BE O.K. I WONDER IF I SHOULD TRY AN ELECTRIC FUEL PUMP AND A PRESSURE REGULATOR. I HAVE TRIED TO TIME IT BUT IT RUNS GREAT AT IDLE AND TIMING LIGHT SHOWS IT TO BE AT AROUND 10 DEGREES. AS FAR AS I KNOW I HAVE EVERYTHING INSTALLED CORRECTLY ONE VAC LINE TO DIST. AND CARB VENT TUBE TO CHARCOAL CANNISTER.
post #4 of (permalink) Old 02-27-2002, 09:28 PM
Re: weber carb
Is the timing advance working ok? I mean, both mechanical and the vacuum ones? I'd also check the vacuum in the manifold, and the valves. It may have slipped the timing belt or dropped an intake valve...
Sarge
If it aint broke , I can still fix it...
Sarge is offline
