in need of efi help - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-21-2002, 06:22 PM Thread Starter
in need of efi help
i am in need of some help. my samurai is running a complete gti engine with efi and starts and runs great with gobs of high end power...until recently.
the problem as of three days ago is it is nearly imposible to start. when it does start it idles perfectly, but if i hit the accelerator, it tries to die and it will unless i let up on the throttle. it seems like teh harder i hit the throttle, the more it chokes out the engine. however if i very SLOWLY increse the throttle, it will rev up ok. the fuel pump i am using is a high pressure in-line pump out of a v8 ford efi pickup and it is relatively new as is teh battery and starter. this set up worked great up until this point.
i know most of you do not run the same set up as i do, but maybe someone has ran into the same sort of problem before with efi. i am just completely puzzled at this point and would like some other ideas.
thank you for any ideas, jerry
blue_zuk is offline
post #2 of (permalink) Old 02-21-2002, 07:14 PM
Re: in need of efi help
Check the advance in the distributor. Sounds like it's not advancing. Does that engine use a vacuum advance at all? I don't think they do, but might be part of the problem.
Sarge
If it aint broke , I can still fix it...
Sarge is offline
post #3 of (permalink) Old 02-21-2002, 09:37 PM
IMC2112
Have you checked the throttle position sensor? Even with no advance you Gti should run but not very well.
No Guts, No Glory!!!
post #4 of (permalink) Old 02-22-2002, 05:21 AM Thread Starter
thanks, i will check the throttle position sensor with an ohms meter this weekend. i have never had to adjust it since it came out of the car, so it is still adjusted as it was at the factory. i have a spare i can toss on as well. efi is great when everything works right, but when something goes wrong....man it gets frusterating.
jerry
blue_zuk is offline
post #5 of (permalink) Old 02-22-2002, 06:28 AM
Check fuel pressure, return lines?
Did you pull the check valve outta the return line?
Hmm...
93 Tracker, deceased
87 Samurai.. 1.6 YAHOOO It RUNS!!
88 Samurai.. doesn't run, all rotted
ICQ: 12438978 AIM: Mini4x
Mini4x is offline
post #6 of (permalink) Old 02-22-2002, 07:24 AM Thread Starter
mini4x, yes i did pull the check valve from the return line. thank you for pointing that out though because i think that is the single most over looked thing in a zuk efi swap.
since it is a high pressure fuel pump i would have to borrow a pressure tester from my buddy at the ford garage, as the only one i have is for low pressure. if the TPS checks out ok, i will go ahead and check the fuel pressure. thanks for all of the pointers.
jerry
blue_zuk is offline
post #7 of (permalink) Old 02-22-2002, 11:41 AM
Almost all efi engines only look at a 2 or 3 sensors when starting......the most important on being the coolant temp sensor,then the throttle position sensor,then maybe the airtemp sensor......That is if it has spark.If not start with crank/cam sensor's and check coil,then move on to the fuel control sensors.
porschefixer is offline
