clutch thingy? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-22-2001, 07:53 PM
clutch thingy?
I have a 97 600xcr and am wondering what the little adjustment dial on my secondary clutch is. It has a 1-3-5 on it and is set at 3. What does this adjust and how would I adjust it if I wanted to?
post #2 of (permalink) Old 01-23-2001, 07:38 AM
Matt M38A1
Re: clutch thingy?
If you don't know what it is, why would you want to adjust it?
Just kidding. Its for adjusting the neutral (or low gear) postion of the secondary sheaves. A brand new belt should ride out of the sheaves about an eighth of an inch when the clutch is closed (or low gear). If you look closely at that dial you'll notice there are ramps stamped into it. Inside the secondary there are pins that set on these ramps. Turning the dial allows the pins to move on these ramps, and makes the sheaves open or close as necessary.
post #3 of (permalink) Old 01-23-2001, 11:41 PM
Re: clutch thingy?
Thanks Matt. When would you have to adjust this? As the belt wears, or if you would happen to switch brands of belts and there is a width difference? Seems to be fine right now, but I would like to know for future reference. Thanks for your help.
post #4 of (permalink) Old 01-24-2001, 07:58 AM
Matt M38A1
Re: clutch thingy?
You really don't. The older machines had to have the secondary disassembled to make that change. The dial just makes adjustment easier, particularly for racers trying to get the best holeshot possible. When your belt wears you should put on a new one anyway, then your back to square one. Mountain riders may pull the belt out a bit more so they have a lower "first gear", that sort of stuff.
I wouldn't mess with it if your just riding, mostly because if it's set right (with a new belt) you don't need to.
