-   Snowmobile Lounge (https://forums.off-road.com/snowmobile-lounge/)
-   -   92 rxl questions (https://forums.off-road.com/snowmobile-lounge/51542-92-rxl-questions.html)
**DONOTDELETE** 01-05-2001 12:43 AM
92 rxl questions
just bought a 92 rxl with 5300 miles on it even though my friends said not to . are these sleds a real headache?
sled had set for 2 years out side and we put a battery in it and it fired the first pull . havent checked compression yet but it felt as good or better than my 93 xlt special with 2500 miles on it . just found this place and it is a wealth of info .
Matt M38A1 01-05-2001 08:03 AM
Re: 92 rxl questions
Mustang-
You got a good machine as far as I'm concerned. I have a 1990 indy 650, and the motor is flawless after 6400 miles. My buddy has a 92 RXL with pipes a chip and a clutch kit. Usually mods mean only trouble but he has never had a problem. In fact he is so content with it that we put an Xtra 10 suspension under it this summer.
You want to make sure when you kill it that you shut the key off as well. The ignition/fuel pump will stay hot otherwise, and will drain the battery. My buddy found that out the hard way! The only other trouble I know of that he has had was that it dropped an injector once. No big deal, If i remember it wasn't that expensive to have fixed. Also, it has a cold idle circuit, and it(at least my friends) doesn't like to move at all until after a couple minutes of warm up. So don't think you've fouled any plugs until after you let it idle for a bit. They will foul plugs though, My buds dad has a 92 RXL SKS, and it did foul even after the warm up. Just changed 'em out and it was fine.
The only other thing I can think of would go for any machine. 5300 miles, has it had a rebuild? If not you may need a top end within a couple years. Also, have the clutches been gone through? Check the primary rollers for flat spots, rust. If the rollers seize or wear out their bushings, and the clutch starts to bind you could be in for big money. I rebuilt my clutches this summer, for less than 60 bucks for both. Finally, just idler wheels and bearings? They're cheap enough.
Have fun, they get great mileage I think you'll like it. I'm considering getting a 1995 one as my backup machine.
**DONOTDELETE** 01-07-2001 01:30 AM
thanks for the input matt . i checked the rollers and found some bad bearings and greased the suspension . the fly wheel side jug was 8lbs. lower on the comp. that the other 2 . my friend and i rode today . i was on my 93xlt spec. and he rode the 92 rxl . it was about 35deg f. out and i think the rxl pulls stronger than my 93 xlt . iknow that efi cars usally make more torque down low so i can only asume that it would be the same for snowmobiles .
thanks again ,
Matt M38A1 01-07-2001 05:23 PM
Don't worry about the 8 lbs, it should be OK.
Also, the RXL pulls/runs faster because it's a 650. The XLT is a 580! [img]/wwwthreads_images/icons/laugh.gif[/img] Those bearings are cheap enough, get em replaced and save yourself a little gas. Have Fun!!!
**DONOTDELETE** 01-08-2001 07:36 PM
one more question . what mods can i do to this sled since it has efi ?
Matt M38A1 01-09-2001 08:04 AM
My friend's has a set of pipes on it. I think they come with a computer chip to make the appropriate adjustments, or you have to get it separately. His also has a clutch kit on it as well. I would guess you can pretty much do anything.
