-   Snowmobile Lounge (https://forums.off-road.com/snowmobile-lounge/)
-   -   00 ZL500EFI problem (https://forums.off-road.com/snowmobile-lounge/50932-00-zl500efi-problem.html)
**DONOTDELETE** 12-30-2000 11:15 PM
00 ZL500EFI problem
700 miles on machine, i bought it used. it bogs at low rpm's(2000-5000) almost likes it missing on one cyl. but it runs fine at high rpm's. it also has been using more oil than it should. Oil pump is adjusted according to manual. fuel mileage isn't what should be expected either. can anyone tell how to fix this problem.
**DONOTDELETE** 12-31-2000 12:38 AM
Re: 00 ZL500EFI problem
At what rpm are you engaging at?
That 500 gets about 9-10mpg BTW.
Punch Da Throttle and ROOST!!
**DONOTDELETE** 12-31-2000 12:46 AM
1st. There is no power at 2000, 3000, or even 4000 rpm on that engine. You may have a broken front clutch spring or flat rollers or a belt that is way too long. You should engage that engine at 5000 rpm. Check those things out
Please check out my aftermarket 2-stroke heads at:
http://www.geocities.com/torqueline
