-   Snowmobile Lounge (https://forums.off-road.com/snowmobile-lounge/)
-   -   81 CITATION (https://forums.off-road.com/snowmobile-lounge/50010-81-citation.html)
**DONOTDELETE** 12-21-2000 10:11 AM
81 CITATION
I have an 81 ski doo citation 4500 with a 377cc rotax twin,single carb. My problem is ihave one cylinder which is backfiring threw the carb. I have changed the plug and the external coil this has made no difference. thanks f15
**DONOTDELETE** 12-22-2000 12:45 AM
Re: 81 CITATION
first you'll have to take a compression test to see if the cylinders are near equal pressures then we can go from there
**DONOTDELETE** 12-22-2000 10:48 AM
Re: 81 CITATION
i have done a compression check and have 120psi in each cylinder . the cylinder that is backfiring ,ihave been having problems with the plug fouling out. thanks f15
**DONOTDELETE** 12-23-2000 08:19 PM
Re: 81 CITATION
check your porting. had acoil that went bad. i dont think it was that. check the pipe. see it is flowing freely.
**DONOTDELETE** 12-24-2000 01:08 AM
Re: 81 CITATION
replace the cap resistors on the ends of the spark plug wires they are cheap and they will cause this problem when bad, it will need them anyway.
