WOT Surge: - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-23-2000, 06:47 PM
WOT Surge:
I have a 2000 RMK 700 with V-Force reeds, SLP single pipe, TCP clutch. My problem is it surges at WOT.
Can any one help me solve this problem? 90-95 jets at 6000' - 9000' bottom and mid seem fine.
Thanks Jack.
post #2 of (permalink) Old 01-24-2000, 06:47 PM
Re: WOT Surge:
Add more clutch weight.... Run it around 7900 RPM....
post #3 of (permalink) Old 01-24-2000, 07:31 PM
Re: WOT Surge:
I run a 50/32 helix, 62.5 lightning weights, SLP black/gray spring in the driven, stock almond in drive. They sent a dark blue
for the drive, just got the puller so haven't tried it yet. Do you think it will help.
Thanks Jack.
post #4 of (permalink) Old 01-24-2000, 09:34 PM
Re: WOT Surge:
Dark blue will drop your peak R's a little. You need to make sure you are not running over 7900. What jetting you running? What elevation?
Corey
post #5 of (permalink) Old 01-24-2000, 10:05 PM
Re: WOT Surge:
I'm running 90-95 jets, I ride 6000'-9000', seems to turn about 8100 RPM with almond spring.
Thanks for any help Jack.
post #6 of (permalink) Old 01-24-2000, 10:16 PM
Re: WOT Surge:
8100 is a little high. The dark blue may drop it. Is your helix a 50-32 short? You can also try your stock silver/blue driven spring if the dark blue does not drop you enough. What hole you running you driven in?
Corey
post #7 of (permalink) Old 01-25-2000, 07:58 AM
Re: WOT Surge:
Yes it's 50/32 short, I'm running in the second hole
post #8 of (permalink) Old 01-25-2000, 08:19 AM
Re: WOT Surge:
If you are pulling that good, you may want to try a 50-32 long or a 46-32 long. I found that the 46-32 long pulled better than the 50-32 short, but you did loose a little RPM, which would be good for you...
Corey
