XLT Cooling System Troubles - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-09-2000, 11:18 PM
Leaving the coolant pump there is "pressed in" tube that has has become loose. Once the coolant pressure builds the coolant blows by the tube. I tapped it a couple times with hammer and it fell out of the case. Nice Huh? Now that is engineering! I don't really understand why it isn't threaded.
So how is the best way to fix this? I keep thinking I should pull out the tap and die set and cut some threads so this can't ever happen again. Or is the answer some Loctite/Sleeve Lock.
If anyone has had this problem or can help recommend a fix I would appreciate it.
post #2 of (permalink) Old 01-10-2000, 05:45 PM
Re: XLT Cooling System Troubles
Why don't you hit it with your hammer again,maybe you didn't swing hard enough. Just make sure somthing runs for the big road trip.
post #3 of (permalink) Old 01-10-2000, 10:35 PM
snownut
Isn't the saying "get a bigger hammer"?
Snownut
post #4 of (permalink) Old 01-11-2000, 03:24 PM
Had the same problem on a friends XCR600. I cleaned up the surfaces with some scotchbrite and and pressed the tube in place using a high temp locktite cylinder fluid. I also used an industrial type epoxy around the fix. So far it is holding. I agree it is a poor design.
