Mojave Mods - Off-Road Forums & Discussion Groups
Performance ATV Mods Discussion of ATV Performance Modifications.
post #1 of (permalink) Old 12-10-2008, 09:35 AM Thread Starter
Mojave Mods
I just pickup an 89 Kawasaki Mojave it was already set up with a DG exhaust and K&N filter. I was wondering If there was another option for an airbox other than stock or K&N. I am not a big fan of K & N filters and it needs to be replaced. Is there a carb I could replace the stock one with to get better performance (AKA kx 125 or an other 4stroke 250 carb). Thanks
molson00 is offline
post #2 of (permalink) Old 12-10-2008, 12:05 PM
ahh yes someone else who knows K&N air filters are not that great
what i would do is buy a UNI or twinair air filter and also drill some holes in the air box lid or remove the air lid (some moddles you cant remove because it holds the filter in place, but im not shure about mojaves) but if u can remove it all the way i would.
i would leave the stock carb on there (other carbs from diff machines will just lead to problems)
just jet it up for the pipe and filter/airbox and you can lower the needle clip by one slot. but check how lean it is running first after re-jetting it by checking how lite colored the spark plug is (dark/black=running rich, white or lite colored=lean)
there are some after market carbs out there desighned for the mojave (edlebrock) but it wont be worth it at all and will cost about 300-400 dollars
you should do other mods like, performance cam, high compression piston, and port&polish and even big bore/stroker crank way before you buy another carb.
Mr_RPM is offline
post #3 of (permalink) Old 12-10-2008, 05:06 PM Thread Starter
RE: Mojave Mods
Thanks Mr_RPM.
Unfortunalty this Mojave's airbox is long gone. The stock airbox is also a 2 stage unit seeming very restrictive. The carb that came with it was not stock or even fit under the frame rail "Complete Hack job". I found a stock carb and am looking to replace the K & N with something more Trail friendly. I would NEVER recommend a K & N filter to anybody who does normal trail riding. You end up with more dirt in the carb and engine than it blocks. For all you true believers of K & N they are very good for racing applications. Sorry I have had BAD experiences with K & N. This is my 1st Mojave, I am not looking to spend $1000 on mods not on this Quad. Just a play toy. Thanks
molson00 is offline
post #4 of (permalink) Old 12-11-2008, 11:50 AM
well its not that i have found they let alot of dirt threw (but yes more than foam, you were oiling your K&N right?)
but i have found that they just dont breath like a foam filter
the few K&N i have used were more restrictive and did not filter as well
so why even think of useing one
but good luck with the quad
and if u were you id put that stock carb u found on
Mr_RPM is offline
post #5 of (permalink) Old 12-16-2008, 10:33 PM
ive used k&n filters for many years in the woods/dusty conditions with no problems what so ever. they obvious are not scared to post up there performances tests on their site, you dont see uni doing that.
K&N Product Testing
If you dont ride in any areas where your going through creeks you can actually buy a clamp on air filter were you completely ditch the airbox. Also, when you are trying to "tune" your carb. dont start with the needle clip position like RPM said. Dial in your main jet first and then work your way down the jetting circuit (Main, needle clip, pilot, then theres a fine adjustment screw somewhere on the carb.
As for mods, i would take a compression test first and see if your engine needs a rebuilt and maybe through in a cam while your doing that.
alpinestar64 is offline
post #6 of (permalink) Old 12-17-2008, 09:14 AM
do you work for K&N or something
most of the tests i have seen from K&N (i have not seen any atv tests but im shure they are there)are comparing from paper air filters, whichn yes suck compared to K&N
the clamp on filters that are put in place of the air lid i think are just a waste of money because a stock or UNI or any aftermarket foam filter will filter the air perfectly if oiled and maintaned right. the clamp on will just if anything (it dosent) restrict it more than just an open box
the only thing i would buy it for personally would be if i had a K&N filter on the machine and the extra filtration would be nice
or to keep mud clumpos out of the box itself but if u are in those conditions
just use the stock air lid.
this is all just personal experience and no im not a research lab test with fancy machines and computers
just letting the public know what i have found best
but i do know many people who dislike K&N
Mr_RPM is offline
post #7 of (permalink) Old 12-17-2008, 03:43 PM
No, I just stated that I have never seen a filtration/performance test on any of the foam filters. if you would have clicked my link and read it you would know that its not a comparison against a paper air filter. it is actual data that their "testing equipment" gathers, not just some kid that says this filter is better than that one.
Reread my post i said a clamp on filter that clamps directly onto the carburetor hence eliminating the air box
k&n collects actual data, which i cannot find any filtration information on uni's website.
post #8 of (permalink) Old 12-17-2008, 03:59 PM
yeah i have seen the tests from K&N
showing the volume of air flow and all that
yes their testing is very well done
but is it true?
could be and most likely is
but at the dealer i work at
and stand as a tech
i have found machines run richer with the K&N (yeah some of the K&N was used but clean. K&N claims life time warrenty so that shouldent matter)
i had a guy put a K&N filter on his yamaha warrior and then it would sputter and beg for air. with the filter off it ran fine (this was a new K&N with about 5 mins of sputtering warrior sucking air threw it)with his stock filter it still sputterd. but then we cleaned it with solvent (we knew it was rich by the plug)and with the clean freashly oiled stock foam it ran fine.
but he was looking for something better than stock (reason he bought K&N)
so we sent him out with a new UNI and he was happy and it ran fine.
thats the worse case of a K&N i have had.
we put a K&N on a all stock ltz 400 and it ran richer than stock (both new, it was right after the guy bought it he wanted the K&N installed when he bought it)
but some people buy K&Ns from us and say they love them.
i just havent seen any improved air flow from them and they filter less
but that dosent mean im right. just havent been lucky with em i guess
and another u said K&N aint just a kid saying whats better
i am 38
sooooo lol
but no im not professionaly testing
and im not able to say whats better
just whats better in my opinion
but who care really
what ever works for what machine really
Mr_RPM is offline
