Need Help IDing this GM Compressor - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-25-2001, 03:44 PM
MarkF
Let me start by saying hopefully this will some how attach to the Chevy 350SB in my 86 CJ7.
Now I need to know what this is, if it is any good as an air compressor, and if I have all of the necessary brackets.
Thanks in advance
Mark F
1986 CJ7, Chevy 350, D44/D30, more to come shortly
post #2 of (permalink) Old 12-25-2001, 03:47 PM
MarkF
Re: Need Help IDing this GM Compressor
anther pic
post #3 of (permalink) Old 12-25-2001, 03:49 PM
MarkF
nother
post #4 of (permalink) Old 12-25-2001, 03:50 PM
MarkF
last one
post #5 of (permalink) Old 12-25-2001, 04:38 PM
Nickmil
That's a Frigidaire Compressor. They were used on GM's, particularly in the mid '70's. you will need the brackets from a mid '70's GM car or truck with a sbc v-8 and a/c. Get all the brackets and pulleys. Good luck. Nickmil.
post #6 of (permalink) Old 12-25-2001, 04:55 PM
MarkF
So I take it I'm missing some brackets? Will this work for onboard ar?
post #7 of (permalink) Old 12-26-2001, 08:13 PM
Nickmil
Yup, You are missing some brackets. It will work great for on board air. It has its own oil sump and an internal oil pump. You will periodically need to check the oil as you will lose some but not much. The biggest down fall is it is heavy. Nickmil.
post #8 of (permalink) Old 12-26-2001, 11:24 PM
That's an A6, you scored a good compressor. It's the only GM "log" type with a oil sump. It has a very high air volume(comparable to a York) and psi(300 lbs continuous, over 400 peak). I've used one of these for over 4years for OBA and it works great. Fills a 38.5x 14.5 from 10 to 30lbs in about 45 seconds without a tank.
Your missing brackets, one from the intake manifold to the bracket that you have. One that bolt to the front of the block and one that bolt to the front of the compressor around the pulley. If you still have the donor motor, get all the pulleys off it. It will most likely have a smaller waterpump pulley which is good for trail RPMs, the fan speed and water flow will be increased.
Wayne @ Big Island RockCrawlers
"PYRO" The Rock Crawler
Web Site: http://www.members.tripod.com/surfmac/Index.html
W.C. is offline
post #9 of (permalink) Old 12-28-2001, 11:25 AM
MarkF
Cool, not for bad for $10 (+15 shipping). Now we'll have see how much the brackets will hurt me. No wonder it needs 3 brackets it weight a ton.
Thanks for all the help guys.
Wayne - Do you have pics of yours installed?
Mark F
post #10 of (permalink) Old 12-28-2001, 12:25 PM
Here ya go
W.C. is offline
