Am I flooding the engine?? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-21-2001, 06:14 PM Thread Starter
Drury's Avatar
I've been temporarily stranded 3 times in the last couple of days. When the engine is warm turn it on and have a fast acceleration right away, the engine peters out. Then it won't start for about 10 mintues. Finally it will just start again and I'll be on my way. Am I flooding it?
78 CJ7 Golden Eagle/TR Ignition/Weberized/2" leafs
Drury is offline
post #2 of (permalink) Old 12-21-2001, 06:30 PM
Caver Dave's Avatar
Re: Am I flooding the engine??
Or you fuel filter is clogged! I had a bud with a '67 Mustang (I6 [img]/wwwthreads_images/icons/frown.gif[/img]) that died every 10 minutes. My dad blew of the fuel filter and it ran for days. My bud eventually replaced the filter, hours before a little 'offroad" trip through a pine thicket.
Caver Dave
'72 Commando
(Now "Moss-less" & looking for a name)
Caver Dave is offline
post #3 of (permalink) Old 12-21-2001, 06:30 PM
do you pump the gas pedal at all before you start it? Open the hood after it dies the first time. You could assume it floods if you smell gas(obviously) or the choke could be inoperative
post #4 of (permalink) Old 12-21-2001, 06:32 PM Thread Starter
Drury's Avatar
I believe my choke is inoperative. The reason I say that is when I installed the Weber, I set the fast idle when it is at full choke. However, the choke never engages on its own. I guess I need to call Weber to figure why the choke isn't working.
Drury is offline
post #5 of (permalink) Old 12-21-2001, 07:34 PM
I would suspect the ignition module. That's how they go bad, after they're warm they die, then they work again after cooldown. Even if that's not it, they are under 20$, and I always carry a spare one, because sooner or later either you or one of your buddys will need it. Just a part of your trail insurance package.
CTjeepnut
You had to do what to fit those little tires?
I'm sure glad I own a CJ!
post #6 of (permalink) Old 12-21-2001, 08:41 PM
Dury-
When I had a Weber (which was piece of junk that Weber could not fix but stuck me with) I leaned that what sounds like flooding with that carb is actually starving.
Good Luck!
Kriss
post #7 of (permalink) Old 12-22-2001, 02:55 AM
When you depress the pedal before you start it when it is cold, it sets the linkage on the fast idle cam on your carb, which will increase the rpms for you for a faster warm up. During that time, the choke is engaging itself and when it is warm you can tap the pedal again to release the linkage from the cam to bring it down to normal speed, at which time the choke should have fully engaged itself. So my bet is that it isn't a broken automatic choke, it's the fast idle cam out of adjustment. It should say in the service manuel what the fast idle speed is, I have mine set at 1500 rpm.
The problem I have is I will pump the pedal twice start it, it will die, then I will pump it again and then run. Takes about 2 minutes to get warm enough to drive(so it doesn't stall). I have the Weber 32/36, by the way. This might seem confusing because I am tired but that is how the choke works on these carbs(to my knowledge). A more usual problem on these carbs is an air leak in the mounting base. Good night...
Tim
post #8 of (permalink) Old 12-22-2001, 11:32 AM Thread Starter
Drury's Avatar
Tim,
Should I pump it twice with the ignition on or off before cranking?
Also, what are the symptoms of an air leak at the base?
Drury is offline
