Engine dies when clutch is pressed in - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-21-2001, 12:26 AM Thread Starter
jamgood96's Avatar
I'm having a little problem with my YJ dying when I put the clutch in and let it coast. It's happened about 4-5 times today. Funny thing is, this never happened before. Then a guy was curious about the self-diagnostics on my YJ, so he checked my codes. He came up with four. I don't remember the numbers. But one was for my speedo, which isn't hooked up yet. One for some A/C relay, and I lack A/C. There was a code 12 that he couldn't find in his book, but thought it was maybe that I unhooked my battery recently. And the other was a code 21 I beleive. Had something to do with the O2 sensor. But I just replaced that damn thing 6 months ago after I ripped the wires out 4x4n. Anyone go any ideas on what about be wrong? Also, I did I cycled the ignition 3 times and got the flashing light for the codes, but how do I read it? How do you get 21, 12, etc out of it? Thanks!
UPDATE: I think I figured out howto read the codes. Here's what I got.
12 Battery or computer recently disconnected
33 Air conditioning clutch relay circuit open or shorted (may be in the wide-open-throttle cutoff circuit)
15 No speed/distance sensor signal
21 Oxygen sensor signal doesn't change (stays at 4.3-4.5V). Probably bad oxygen sensor
55 End of codes
Everything is fine except for code 21. Think I just got a bum O2 sensor? Hopefully the parts store will warranty it out.
http://www.webphotos.com/list_albums...2&u=1000020268
jamgood96 is offline
post #2 of (permalink) Old 12-21-2001, 01:02 AM
Re: Engine dies when clutch is pressed in
Kinda sounds like a vaccuum leak.
TJ
teejay68 is offline
post #3 of (permalink) Old 12-21-2001, 11:47 AM
Take a look under the dash maybe there is wires from the ignition that have the outside worn off and short against the metal clutch pedal arm when it's depressed.
Take care of the pennies and the dollars will take care of themselves.
post #4 of (permalink) Old 12-21-2001, 01:01 PM
that battery computer disconnected recently sounds interesting because the computer should keep the engine running when its about to stall...my YJ has fallen below normal idle a couple of times but the computer always keeps it going. Reset the codes and see if that code comes up again. I would agree that it sounds like the clutch might be hitting a connection and knocking it loose causing the stall...good luck with it anyway though
Jay
95 Wrangler Rio Grande...She's gettin there - I'm all about the 4 cyls
post #5 of (permalink) Old 12-21-2001, 01:56 PM Thread Starter
jamgood96's Avatar
So I shouldn't even worry about code 21? Why does the batter/computer disconnected recently sound interesting? My battery has been disconnected recently. How do I reset the codes?
post #6 of (permalink) Old 12-21-2001, 07:55 PM
Same thing happened to my 94 , when my son was borrowing it, before he bought it. Seems like he was trying to do me a favor by not racking up a lot of miles on his dad's Jeep, so he unhooked the speedo at the t-case. Hooked it back up and problem went away. I think the computer needs to read the speedo.
CTjeepnut
You had to do what to fit those little tires?
I'm sure glad I own a CJ!
