Transmissions,driveshaft lengths and axles ratios - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-13-2001, 10:14 AM
1. I have a three speed that was intended for my CJ-5 project. I don't realy like the 3-speed idea, this will be a road-jeep primarily. I may have a SR-4 available to me, but I understand they are weak. I have considered an auto which would also please my wife(yeah I'm whipped). I haven't looked into the auto very much but aren't they usually longer that manual boxes?
Are any of you running an auto in your CJ-5s? If so, which ones, TH350/400 or 700R4 and what transfer cases work with these.
Any opinions on the SR-4 being weak?
Finally, the axle ratios. The ones I have were used on an '81 with a 4 cyl and an SR-4 trans. I would dhave guessed that these would be a high ratio axles with the low output of the 4 cyl. I jacked up the jeep so that one wheel was off the ground, turned the input shaft on the front diff 10 times and the wheel turn almost 5 times(~4.75 best estimate). Would that not make these approx 2.73?
post #2 of (permalink) Old 12-13-2001, 10:31 AM
I Do This For The Glory
JEEPN's Avatar
Re: Transmissions,driveshaft lengths and axles ratios
The only ratio available with that combo in '81 was 3.73's. That being said, I have an '80 leftover (it comes up as an '81), same combo, with 3.54's in it.
The SR-4 is junk, don't even consider it.
What engine are you going to run, Chevy?
JEEPN
Winter Harbor, Maine
'88.5 Zuki, 7" Lift, Locked, Swamped, Rolled, and just generally broken in right!
JEEPN is offline
post #3 of (permalink) Old 12-13-2001, 10:45 AM
Thats what I was thinking on the SR-4. I have a 304 that I planned to use simply because I already have it. I have a bell housing that I haven't identified yet, it has GM-4 stamped on the transmission side. I think I will take some pictures of it and let you folks ID it for me if you can.
post #4 of (permalink) Old 12-13-2001, 10:56 AM
RickB's Avatar
JEEPN - Are you sure that 3.73 were the only option for that combo in 81? A buddy has a '81 scrambler with the iron duke and sr4 and says that he has 4.11 gears.
Rick
80 CJ7
RickB is offline
post #5 of (permalink) Old 12-13-2001, 11:39 AM
JEEPN's Avatar
Yep, that's straight from the factory manual. He may have a crossover year, but the 4.10's weren't an option since '79 on the CJ's.
The only reason my '81 has 3.54's is it's a crossover year, it's doubtful the Scrambler he has had the 4.10's from the factory, because there's a year gap.
JEEPN
JEEPN is offline
post #6 of (permalink) Old 12-13-2001, 12:13 PM
As for an auto in a CJ5, it's usually not done due to the short wheelbase. About the shortest available auto you could fit in there would be the aforementioned TH350. This tranny is best used with a GM engine, and will need adapters to mate to the TC. To be honest, I've never seen or heard of a CJ5 with an auto in it.
A word on the three-speed... if it's primarily a road Jeep, the three speed won't be much less desireable than a four-speed. 3 and 4 speeds have a final gear of 1:1. If considering a manual roadwise improvement over the 3-speed, think of a 5-speed. Overdrive is a real plus for road manners.
Assuming your 3-speed is a T-150, I wouldn't swap it on the SR4. The T150 is a heavy-duty tranny, the SR4 a light tranny. 1st gear on the SR4 is only 4:1, not that much better crawl-wise than the T-150's 3:1. If you're interested in double-duty, there's always a good old granny 1st T18 or NP435 or SM420/465 ultra-macho 4-speed.
Sometimes you eat the bear, sometimes the bear eats you
fullygruntled is offline
