75:1 low enough? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-12-2001, 09:18 AM Thread Starter
75:1 low enough?
so i was using one of those gear calculators and with 4.10's id come up with about a 75:1 final drive ratio with 36's in low. this would get me about 2200 rpm @ 60 mph in regualr driving mode. any lower and my gas miliage goes strait to hell. so do yall think 4.10 will be low enough offroad? what does everyone else get for final drive ratio.
Is it ok to yell "movie" in a crowded fire house?
lifted95z71 is offline
post #2 of (permalink) Old 12-12-2001, 09:34 AM
Re: 75:1 low enough?
That isnt bad. The holy number is 100:1 for crawlers, but most people can get by with less than that. I'm currently running at 86:1 and plan to be over 100:1 when I'm done with the axle swaps.
cjcrawler
"The Beast"
http://ucsub.colorado.edu/~simmonst/Jeep.htm
post #3 of (permalink) Old 12-12-2001, 09:52 AM
crawl ratio is dependent on what type of wheeling you do, if you are playing in the rocks then real low is good, but if you are into mud it is not as much of an issue. 75:1 sounds about perfect to me. Unless you are into rocks.
91 YJ 2 inch lift new engine in the works.
"Because there is no reason not to"
Olin18 is offline
post #4 of (permalink) Old 12-12-2001, 12:55 PM
My opinion, 75:1 is about as good as you really need short of , well short doing things that no streetable rig should be doing. I've known guys with all the way to 24x:1 and found that 98% of the time, anything more than 75-100:1 is wasted. AS far as the 4.10s, probably be fine on the street up to 33s or 35s with an automatic, maybe even 35s with a manual if you're beyond hot rodding around town, and at 2200 rpm on the highway you should get decent mpg. If you have dana/dana for axels you might go 4.27 as a compromise between the 4.10 and 4.56s. They're adequate for my CJ 5 with a t18 and 35s (crawl at 71:1)
post #5 of (permalink) Old 12-12-2001, 01:02 PM
mudracer
That should be plenty unless you're into serious rock crawling. Sounds about right for a highway use too. My Heep is at 84:1, but I only use that for big rocks, etc. More often, I'm in 2nd low (43:1) or 1st high (32:1) for the tough trails. I have seen no need to have lower gears than I have now with a 454 and 38's.
What engine & drivetrain are you using?
[img]/wwwthreads_images/icons/cool.gif[/img]
'93 Dodge W250 Cummins 5spd club cab
'80 CJ-7 BBC, 1 ton
'85 Honda XR350R
post #6 of (permalink) Old 12-12-2001, 02:36 PM
post #7 of (permalink) Old 12-12-2001, 03:50 PM
Hey, your profile says you live in the south, i'm thinking that's south east which is most mud or mud covered rocks so that should be more than enough, 50:1 is probably better suited to that type of wheeling though 4.56's might be better for the high way and would lower your crawl ratio a little if you want it even lower (extreme rocks).
BarrelRoll
97 TJ
Wheel it or drive a minny van
Jeeper99xj is offline
post #8 of (permalink) Old 12-12-2001, 04:06 PM
Guys what would the cralw ratio be on my best buds TJ be. I know he has stock t case, 5 speed, and 4.88 gears. Also what woudl his rpms be at 60mph???
Mooseykat
85 Bronco XLT, 351W H.O.
32" Big O At's on stock susp.
True dual flomaster 40 series mufflers.
Paint and custom center overhead console soon.
post #9 of (permalink) Old 12-12-2001, 04:21 PM
75:1 is a good crawl ratio, especialy with an automatic, for all but the toughest of rock trails. I have ran the hammers with a 70:1 ratio, and 33" and 35" tires, and it was doable but a lot of clutching. At about 100:1 you can take your foot off the clutch much of the time and concentarte on driving.
If you arent driving regularly on Extreme rock trails I wouldnt worry to much about going lower.
I run at about 135:1 and use the lowest gears all day long in the rocks, but I barely grab anything lower than 3rd gear low, on trails.
Jeff
89 YJ
Adversity is imminent, versatility is mandatory, misery is optional.
H8monday is offline
