5 speed to auto - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-11-2001, 06:02 PM Thread Starter
86CJ7's Avatar
5 speed to auto
How hard is it to swap out the 5 speed (T5 I believe) for an auto in my 86 CJ7? What auto tranny is best for this?
86CJ7 is offline
post #2 of (permalink) Old 12-11-2001, 07:11 PM
Re: 5 speed to auto
IMHO, the TF999....
You're going to need:
1. Transmission.
2. Automatic's neutral safety wiring harness.
3. Floor shifter or Column shifter (and Linkage)for the automatic.
4. Kick-down assembly.
5. Possibly a new tunnel transmission cover.
6. I'd suggest also:
a. Deep oil pan.
b. Clocking ring for the Dana300.
c. Valve body shift kit.
If you're going to be spinning over 33" tires... you may want to go with a TF727.
post #3 of (permalink) Old 12-11-2001, 07:22 PM Thread Starter
86CJ7's Avatar
Re: 5 speed to auto
I have 33" tires and don't plan on changing them. How much money do you think a project like this would cost?
86CJ7 is offline
post #4 of (permalink) Old 12-11-2001, 07:31 PM
Re: 5 speed to auto
It depends if you shop around or not. The transmission is going to be used... and if so, I'd suggest you rebuild it (easy... 6 hours start to finsh) or have it rebuilt since it's out of the vehicle. Take the harness and kickdown linkage with it.
Transmissions run, used anywhere from $110 on up... and a rebuild kit's about $50.
The column you can find at a Junkyard... or use a GM column. Otherwise a LOKAR or B&M shifter will be about $140 to $180.
Shift kits are about $100.
Deep pans are about the same.
