350/305- Small Block Info - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-08-2001, 11:41 PM Thread Starter
<font size="5">Basic Engine Displacements & Related Specs</font>
<hr>
<table border="1">
<td height="17" width="51" style="height:12.75pt;width:38pt">Engine</td>
<td class="xl25" width="63" style="width:47pt">Year</td>
<td class="xl26" width="39" style="width:29pt">Bore</td>
<td class="xl26" width="48" style="width:36pt">Stroke</td>
<td class="xl26" width="95" style="width:71pt" x:str="Main Journal ">Main
Journal Diameter
</td>
<td class="xl26" width="88" style="width:66pt" x:str="Rod Journal ">Rod
Journal Diameter
</td>
<td class="xl25" width="64" style="width:48pt">Main Bearings</td>
<td class="xl26" width="64" style="width:48pt">Cylinder Volume</td>
<td class="xl25" width="64" style="width:48pt">Rod Length</td>
<td class="xl26" width="89" style="width:67pt">Compression Height</td>
</tr>
<tr height="17" style="height:12.75pt" align="center">
<td height="17" class="xl32" style="height:12.75pt">262ci</td>
<td class="xl33">1975-76</td>
<td class="xl34" x:num="3.6709999999999998">3.671</td>
<td class="xl34" x:num>3.100</td>
<td class="xl34" x:num>2.450</td>
<td class="xl34" x:num>2.100</td>
<td class="xl33">2 Bolt</td>
<td class="xl34" x:num="32.811">32.811</td>
<td class="xl34" x:num="5.7030000000000003">5.703</td>
<td class="xl34" x:num>1.750</td>
</tr>
<td height="17" class="xl35" style="height:12.75pt">265ci</td>
<td class="xl36">1955-56</td>
<td class="xl37" x:num>3.750</td>
<td class="xl37" x:num>3.000</td>
<td class="xl37" x:num>2.300</td>
<td class="xl37" x:num>2.000</td>
<td class="xl36">2 Bolt</td>
<td class="xl37" x:num="33.134">33.134</td>
<td class="xl36" x:num="5.7030000000000003">5.703</td>
<td class="xl37" x:num>1.800</td>
</tr>
<td height="17" class="xl38" style="height:12.75pt">267ci</td>
<td class="xl39">1979-81</td>
<td class="xl40" x:num>3.500</td>
<td class="xl40" x:num="3.484">3.484</td>
<td class="xl40" x:num>2.450</td>
<td class="xl40" x:num>2.100</td>
<td class="xl39">2 Bolt</td>
<td class="xl40" x:num>33.520</td>
<td class="xl39" x:num="5.7030000000000003">5.703</td>
<td class="xl40" x:num>1.560</td>
</tr>
<td height="17" class="xl38" style="height:12.75pt">283ci</td>
<td class="xl41">1957-67</td>
<td class="xl40" x:num="3.875">3.875</td>
<td class="xl40" x:num>3.000</td>
<td class="xl40" x:num>2.300</td>
<td class="xl40" x:num>2.000</td>
<td class="xl40" x:num="35.398000000000003">35.398</td>
<td class="xl40" x:num>1.800</td>
</tr>
<td height="17" class="xl38" style="height:12.75pt">302ci</td>
<td class="xl39" x:num>1967</td>
<td class="xl40" x:num>4.000</td>
<td class="xl40" x:num="37.718000000000004">37.718</td>
</tr>
<td class="xl39">1968-69</td>
</tr>
<td height="17" class="xl38" style="height:12.75pt">305ci</td>
<td class="xl39">1976-94</td>
<td class="xl40" x:num="3.7349999999999999">3.735</td>
<td class="xl39">4 Bolt</td>
<td class="xl40" x:num="38.478999999999999">38.479</td>
</tr>
<td height="17" class="xl38" style="height:12.75pt">307ci</td>
<td class="xl39">1968-73</td>
<td class="xl40" x:num>3.250</td>
<td class="xl40" x:num="38.347000000000001">38.347</td>
</tr>
<td height="17" class="xl38" style="height:12.75pt">327ci</td>
<td class="xl39">1962-67</td>
<td class="xl40" x:num="40.860999999999997">40.861</td>
<td class="xl40" x:num="1.675">1.675</td>
</tr>
<td height="17" class="xl38" style="height:12.75pt">350ci</td>
<td class="xl39">1967-01</td>
<td class="xl39">2&4 Bolt</td>
<td class="xl40" x:num="43.802999999999997">43.803</td>
</tr>
<td height="17" class="xl38" style="height:12.75pt">400ci</td>
<td class="xl39">1970-71</td>
<td class="xl40" x:num="4.125">4.125</td>
<td class="xl40" x:num>3.750</td>
<td class="xl40" x:num>2.650</td>
<td class="xl40" x:num="50.139000000000003">50.139</td>
<td class="xl39" x:num="5.5650000000000004">5.565</td>
</tr>
<td class="xl39">1972-74</td>
</tr>
</table>
Formula For Figuring CID Of An Engine:
0.7854 X Bore X Bore X Stroke X Number Of Cylinders = CID
So many cats, so few recipes...
Junk Yard Genius is offline
post #2 of (permalink) Old 12-09-2001, 09:23 AM Thread Starter
Re: 350/305- Small Block Info
Anyone know why this HTML script decided to add all that head space between the top line and the table?
post #3 of (permalink) Old 12-09-2001, 01:34 PM
I'm not a super HTML wiz, but I pulled the page up on Navigator using "page source". By my count there should have only been 2 or 3 lines between the title and the table. However, one of the < br > commands was blinking. Never seen that before, not sure. I'll look at it again and see if I can figure out what it's doing. I'll post again if I can.
BTW thanks for the info!
"Fly low, fly fast, turn left!"--advice to new Reno Airracing pilots.
cj5_pilot is offline
post #4 of (permalink) Old 12-09-2001, 01:36 PM
TR- you posted more html code than you neded. you don't need the < html > and < head > and < body> tags. there was also an error where you tried to close the < head > tag with < /head . instead of > .. that is why there is a blinking < br > if you pull up the code in netscape's page source viewer. check over the code, you will see.
Mark
83 CJ-7 and 76 CJ-7 with stuff
sloop is offline
post #5 of (permalink) Old 12-09-2001, 01:42 PM
Not sure this caused it, but when you put the header in you missed the > on the /head part. It looks like < /head. My guess is you missed the shift key and got a period instead of a > Let me know if this helps!
post #6 of (permalink) Old 12-09-2001, 03:54 PM Thread Starter
I fixed that head tag, no change I could see.
I'm about to give up on this table...
I've changed it two dozen times trying to figure out what's with the #%@*&%$ head space [img]/wwwthreads_images/icons/mad.gif[/img]!
It's hand written in HTML, (I'm learning!) and it appears fine in IE and Navigator...
Can't figure out the spacing here though... Maybe just a glitch in the BBS program I'm thinking...
No big secret to HTML, just more than I wanted to do before Christmas...
If anyone figures it out, be sure to post the answer, I'd love to know!
post #7 of (permalink) Old 12-09-2001, 04:50 PM
I still see < html > and < head > tags. they are not needed since you are just inserting into a document. i'm not sure if they are causing the problem, but thats where i would start.
Mark
sloop is offline
post #8 of (permalink) Old 12-09-2001, 05:26 PM Thread Starter
I took out the HTML, HEAD, & BODY tags, and it still didn't make any difference...
This is a real head scratcher for me...?....
