drum brake problem - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-08-2001, 11:53 AM
Joker2002
drum brake problem
Take a look at the pics I have attached and notice how the drum brake appears to be locked in the "full braking" position. Also notice how the rubber end cap has been pulled away from the cylinder on the right side. Trying to get that end cap back where it needs to go has been a struggle with the brakes locked. The emergency brake isn't on, so I don't know what they aren't retracting, or how I can get them to retract. I need some help on how to get that cap back on.
Blake
93 YJ/33x12.50s/3" Heckethorn suspension/1.25" shackles
post #2 of (permalink) Old 12-08-2001, 11:55 AM
Joker2002
Re: drum brake problem
The second pic, showing the end cap more closely.
Blake
post #3 of (permalink) Old 12-08-2001, 12:12 PM
I see brake fluid ...looks like you pushed the piston almost out of the bore...take off the springs and get things lined back up and it should slide right back in
post #4 of (permalink) Old 12-08-2001, 12:24 PM
Drury's Avatar
Do you have the cover off of the master cylinder? You may be fighting against the pressure in the lines.
78 CJ7 Golden Eagle/TR Ignition/Weberized/2" leafs
Drury is offline
post #5 of (permalink) Old 12-08-2001, 12:41 PM
Joker2002
No, the cover is still on the master cylinder. I'll go take it off and wrestle with it. Then if that doesn't work I'll just remove the retractor spring and get the thing aligned. Thanks for the info, all.
Blake
post #6 of (permalink) Old 12-08-2001, 01:42 PM
Isn't their also a self adjuster down at the bottom that may need to be backed off?
'88 Sahara, 4.2 that runs thanx to every Cheap trick on this board. The rest is getting there![img]/wwwthreads_images/icons/blush.gif[/img]
post #7 of (permalink) Old 12-08-2001, 01:46 PM
Joker2002
Yeah, there is. That wasn't the problem though. There was too much pressure in the lines, so I just opened the bleeder valve and compressed the piston with a clamp until it finally gave way and shot brake fluid several feet out of the valve. Once the pressure was off I was able to assemble it again quite easily.
Blake
