YJ Question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-08-2001, 12:04 AM
madmaxx
YJ Question
what year did jeep start putting fuel injection on the I6 YJ's ?
post #2 of (permalink) Old 12-08-2001, 12:31 AM
Re: YJ Question
91 or 92
post #3 of (permalink) Old 12-08-2001, 12:32 AM
Re: YJ Question
The HO version o fthe 4.0 was the first in the YJ and it was released in the '91 model year.
'88 Sahara, 4.2 that runs thanx to every Cheap trick on this board. The rest is getting there![img]/wwwthreads_images/icons/blush.gif[/img]
post #4 of (permalink) Old 12-08-2001, 12:44 AM
Re: YJ Question
what's your cheap trick? Nutter by-pass?
post #5 of (permalink) Old 12-08-2001, 01:22 AM
madmaxx
Re: YJ Question
Thanks
post #6 of (permalink) Old 12-08-2001, 06:02 AM
sas87yj
Re: YJ Question
picked this info:
Jeep Engine: 4.0L I6
Jeep Engines
287(4.7L) V8
360(5.9L) V8
318(5.2L) V8
242(4.0L) I6
150(2.5L) I4
173(2.8L) V6
GM 151 I4
AMC 401 V8
AMC 360 V8
AMC 304 V8
AMC 258 I6
AMC 232 I6
"Dauntless" 350 V8
"Dauntless" 225 V6
"Vigilante" 327 V8
"Tornado" 230 I6
Perkins 192 I4
"Hurricane" 226 I6
"Hurricane" 134 I4
"Go Devil" 134 I4
Engines
Upgrades
Factory Options
General
The 4.0L inline 6 (I6) engine was introduced in the Cherokee in the late 80s and in the YJ in 1991. The cylinder design is based on the changes made to the fuel injected 2.5L I4 engine. The block and cylinder head are cast iron. It uses 7 main bearings and hydraulic lifters. The HP and torque gains are substantial over the older carbureted 258, but the peaks come at higher RPM. The fuel injected engine performs much better in off-camber, bouncy, and steep situations. It also calibrates better for changes in altitude. Fuel economy is also improved.
A good way to embarass yourself in front of your Jeeping friends is to refer to it as a V6. It isn't a V6, it is an inline 6 or I6. The "V" in V6 refers to the configuration of the pistons in the block. The only two V6 engines ever available from the factory in a Jeep are the 225 "Dauntless" Buick V6 in the late 60s and early 70s and the 2.8L GM V6 in 80s Cherokees and Comanches. If you are shopping for a Cherokee or Comanche, make sure you get the 4.0L and not the 2.8L engine, there is a world of difference.
The 4.0L engine used in the Wrangler from '91 until the present.
post #7 of (permalink) Old 12-08-2001, 01:53 PM
Re: YJ Question
Cheap trix
Removing all worn out emmissions garbage.
TR ignition upgrade
Removing computer controlled garbage, (basicly the Nutter)
4.0 head swap
And lots of free advice on tuning and tweaking.
post #8 of (permalink) Old 12-08-2001, 05:52 PM
Re: YJ Question
What do you remove from the emmissions??? are there kits? PLEASE elaborate. How can you remove the computer stuff. PLease help me out. With the 4.0 head can you run the fuel injection?
Headed for Gunnison, soon....
87Warrior is offline
