I have a 95 YJ Sahara, with a 2.5 inch suspension Superlift that is currently spua. I would like to do a spoa, what components would I exactly need, and were could I get them the cheapest? Would this give enough clearance to run 33's? I can run 31's right now.
Thanks!
Amy
'95 YJ Sahara, 2.5 superlift 31" tires, K&N air
'86 Samurai, little bit of mods
'97 TJ Sport, My Fiance's Jeep, too many mods to list
there is a kit to do this.. i think M.O.R.E. sells it.. dont know anything about it.. as far as what you need.. well.. that depends on what work you can do... grind off your old spring perches.. and reuse them.. or buy new ones.. you will have to do something with the steering.. your biggest concern.. longer driveshafts.. longer brake lines...
fit 33" tires.. yes.. more than likely 35's will fit also.. this brings you into the world of new gears..
New brake lines, spring and shock perches, u-bolts and plates, shocks, SYE and CV, longer front driveline, new gears(unless you like big tires and high gears), maybe new steering stuff depending on the route you go, and probably a few more things. Start planning boy!/wwwthreads_images/icons/wink.gif
Those square headlights must be distorting your vision, better change to some ROUND.
Her name is AMY and get this...SHE'S A GIRL!
(Heh heh heh heh)
JEEPN
Winter Harbor, Maine
'88.5 Zuki, 7" Lift, Locked, Swamped, Rolled, and just generally broken in right!
There are lots of sites for this upgrade. Each are so different, that you almost have to look at them and pick and choose what you like and what you don't.. here is a good place to start. SOA starts about half way down the page..http://www.jedi.com/obiwan/jeep/mods.html
JR
"Some People Live An Entire Lifetime And Wonder If They Have Ever Made A Difference, But The Marines Don't Have That Problem" R. Regan
You will need shocks , both driveshafts , steering mods , brake lines preferably stainless steel , 35-38 inch tires , and way more gear . Of course like others mentioned spring perches that need welding and mabe new shackles and bushings .
stock junky Jeep
Related Threads
Off Roading Forums
1.4M posts
22.4K members
Since 1999
