They used an extra "spacer bracket" #24 on the 1976 (only) CJs.
Plus they used an extra "tie plate" #27 on non power steering models 1976+
So if you are going from manual to PS ... no problem. /wwwthreads_images/icons/smile.gif
Not a problem. I had to replace the mounts on my power steering with spares from a manual steering box when I ripped the mounts off the frame. Direct fit and I'm still using them.
JEEPN
Winter Harbor, Maine
'88.5 Zuki, 7" Lift, Locked, Swamped, Rolled, and just generally broken in right!
Yes it will. All Saginaw boxes will bolt up where another Saginaw box lives/lived. The differences are in the input shafts, the output shafts, and the hose attachments. A mid 80's J10 will use o-rings on the hoses, the CJ pitman arm will work on the output, and the input should be 13/16". If you don't have a 13/16" bell coupler they can be purchased from 4WD Hardware.
'75 CJ5 with goodies
Related Threads
Off Roading Forums
1.4M posts
22.4K members
Since 1999
