should I have continuity to ground on the brown wire that plugs into it. ITs the wire that tells the alt to charge is a resitor wire and ties into the othere resistor wire that feeds the coil in run then it goes to the ingnition switch. I also have continuity between the coil + wire and ground. Thanks, I'm just trying to chase some charging problems down.
88 YJ:4.2 I6 TR upgrade and MC2100
