I have a Th400 housing which I think came out of a Jeep truck or something. It has an adapter which bolts between the housing and the block and for the torgue converter. I need to get rid of it.. The case itself had a crack on the inside of the bell housing but it looks like it was pro. welded.
As I said, I need to make room so if anybody is interested, I would take $50 if you pick it up. Thanks.
Hey! Does it have a adapter to a D20 transfer case, we really really need one, we have the TH400, but it is out of a Waggy with Q-trac. For our super awesome race Jeep truck project
OOps, good point, thanks for reminding me... Actually it doesn't have the adpater for the tcase cause I needed it for my swap. So this is just the trans housing, nothing else.
Thanks, but the *engineer* /wwwthreads_images/icons/crazy.gif for the project really wants to use a TH400, for some reason, plus we have about 5 Dana 20 cases sitting around here & the 727 would have to got to a D300.
So you have the housing (any guts or is it stripped?), the adapter ring from BOP pattern to AMC, and the adapter for the end of the crank (about 1" thick w/ centering shoulder on the back)?
I'll pass it along to a fellow Jeeper and see what he says.
The housing is completely empty. There is nothing inside. The trans was fine an I had everything switched over to a Chevy Th400 housing so I could put it in my jeep. The adapter you are explaining is what what I have. Now, I know there are two different BOP patterns. I first tried to find an adapter to the chevy but was unable to match up the BOP pattern that i have. Just keep that in mind.
Mel,
I have a 727 with all the parts to convert it to a dana 20.
it would need put together,also have new rebuild kit,complete with bands,shift kit and new converter.
Dan
Mel85CJ..I think I have a couple th400/d20 adapters sitting out in the shop. Really don't know what there worth so email me if your interested.
Keith
C-Ya.....................kh
Related Threads
Off Roading Forums
1.4M posts
22.4K members
Since 1999
