trans stuck in 1st? help
i pulled my 89 wrangler with POS peugeot trans out of the garage today to put my hard top on. now it is stuck in first gear,the shifter is in neutral but the trans is in first. the shifter will not go into any gear or pull it out of first. the input bearing has been roaring for about a year and i was going to "run to fail" and replace with ax 15. well i guess its failed. prior to this i had no difficulty shifting or anything,just that roar. any help most appreciated
tommy
