-   -   What will happen next? (https://forums.off-road.com/jeep-short-wheelbase/88301-what-will-happen-next.html)
jfralph 09-24-2001 12:41 PM
I know bad luck happens in threes, So I am a little concerned. First, my truck decided it didn't like all the teeth on the front ring gear. So it is out of commission while I await new parts and Send Back all the WRONG parts that are shipped!
Now On sunday, my wife and I took the jeep for a fishing trip, and I don't know if I just really blew the clutch or the tranny is toast. On the trip out, started getting a whine from the drivetrain, severe whine under compression. Got out to the highway and stopped to air up. When I completed the job, I backed up and the tranny seemed to spin while I shifted to forward. but everything worked and I figured get it home and check it out. Well, I didn't make it home. Went to downshift to switch highways, and wouldn't go into third. coasted to a stop, as it would not go into anything. Played with it and discovered; with engine off, jeep would roll backwards with jeep in gear, clutch out. Jeep would hold if clutch pedal depressed. I also discovered if I try to put it in gear while jeep is running, jeep trys to move. I believe I have toasted a clutch.
The thing that has me confused, This is a new clutch, less than 6k miles, with a lot of those being towed. I have never ever toasted a clutch before, I have driven lots of standards well over 140k miles. Never have had a clutch problem. I believe my driving skills are not a problem, however, I would like ideas as to what other causes for early clutch failure other than defective equipment.
Any feedback?
Enjoying Montana's Big Sky
kerryp 09-24-2001 02:06 PM
Re: What will happen next?
check your clutch adjustment and make sure its adjusted correctly. You may get lucky and find that it just needs some adjustment.
kerryp
http://bastroptx4x4.alloffroad.com
CJDave 09-24-2001 02:16 PM
[img]/wwwthreads_images/icons/smile.gif[/img] If I had to venture a guess, I would say that the bell housing has partially disengaged from the engine block. Maybe a fastener broke and the rest were too wallowed out to hold. Check the bellhousing fit against the block. Our CJ was SO BAD when we got it that I had to make special studs to screw into the engine block and slide the bellhousing of that TH400 over them.[img]/wwwthreads_images/icons/crazy.gif[/img] That would also screw your tranny input bearing....hence the whine backing off.....and the complete clutch. Let us know what you find.[img]/wwwthreads_images/icons/crazy.gif[/img]
CJDave
A Jeep Skunkworks run by Moonguys[img]/wwwthreads_images/icons/wink.gif[/img][img]/wwwthreads_images/icons/tongue.gif[/img][img]/wwwthreads_images/icons/laugh.gif[/img], buildin' the ultimate SNOJEEP!
jfralph 09-24-2001 03:26 PM
I will Keep you posted. However, I need to wait until I can get someone to go drag it home for me. It currently sitting at my father-in-laws ranch on the other side of the mtns. So it may be awhile.
thanks, I will look into the loose bolts. Although I seriously don't think that is the problem.
I put the engine, tranny, and T-case in as a unit when I did my build up. I thought I took care to do everything right and correct anything that wasn't.
I have been known to screw up even simpler things however.
CJDave 09-24-2001 03:39 PM
[img]/wwwthreads_images/icons/tongue.gif[/img] In our recent rebuild of a FS GM 4X4 we found the TRANNY TO BELLHOUSING bolts completely washed out because Cletus and Leroy didn't get them in good and tight when they did the Saturday afternoon mill swappin' bee. I made up some extra long studs, Std X NF......screwed them into the bellhousing with Lock-Tite on the threads, and then slid that SM465 over the studs and held that sucker with double NF hex nuts on each stud. That's the trouble with aluminum castings for bellhousings.....without studs it's a MICKEY MOUSE arrangement. Maybe I've spent too much time around those greasy diesels, but to me, studs are the cure for OH SO MANY problems, NOT THE LEAST OF WHICH is exhaust manifold bolt trouble. We have studs all the way on our 304 exhausts, with an oversize nut AND a std brass nut on each one.[img]/wwwthreads_images/icons/crazy.gif[/img]
CJDave
