-   -   Exhaust options for a 360 in a CJ-7 (https://forums.off-road.com/jeep-short-wheelbase/88275-exhaust-options-360-cj-7-a.html)
done 09-24-2001 09:11 AM
I've been going over the information to complete a 360 swap into a 84 CJ-7. I have a question on the setting up the exhaust system. The current manifolds are from a 80 wagoneer. They are both rear dump. Based on the '360 swap guide', the drivers side should be swapped out for one that dumps between the 3rd & 4th cylinders on the driver side. This it is to get the exit past the motor mount and away from the clutch linkage & firewall?
The suggestion is to get a 304 CJ exhaust manifold, would that be both or just the drivers side? I would like to run something as close to the factory 304 exhaust as possible, which means a y pipe and a crossover, to keep the exhaust up and out of the way. I run a Ford T-18/Dana 300 combo, so I think the stock exhuast routing is possible.
**DONOTDELETE** 09-24-2001 09:48 AM
Re: Exhaust options for a 360 in a CJ-7
I had the stock '79 360 manifolds on mine with a T-150 dana 20 and had no clearance issues in the area you mentioned. My exhaust did have to hang down a little below the frame rail but not completely unprotected. I did not run a Y or H pipe.
Kilo-1-6
**DONOTDELETE** 09-24-2001 01:23 PM
Are there any factory/or aftermarket headers available that might fit your conversion?
Sorry I don't have anything to add to your question, but I'm hoping that you can perhaps
help me with mine. Can you send my some information on CJ Dave's 360 swap guide?
I'm looking for any info that would help me put a 5.2 or 5.9 Liter Engine in my 90 YJ.
I like the idea of being able to bolt up my existing NV4500 to the engine without an adapter.
If you know of any links to write ups, that would be awesome.
Thanx in advance.
-Gus-
Enjoying life in San Diego, Cal.
done 09-24-2001 01:50 PM
I was hoping to avoid headers, especially fenderwheel headers. I believe there are some available that fit between the frame rails. I am still looking into that option.
This is the latest revision of the '360 swap Guide'
http://bbs.off-road.com/wwwthreads//...hort&Words=360 swap guide&Match=And&Searchpage=0&Limit=25&Old=allposts
done 09-24-2001 02:17 PM
77 cj-7:
You had rear dump manifolds, running a dual outlet exhaust?
CJDave 09-24-2001 03:30 PM
[img]/wwwthreads_images/icons/smile.gif[/img] The hot rodders who previously owned our 304 CJ7 had installed 401 manifolds on it and both are rear dump using a wye pipe that was shop fabricated. Of course we have no linkage at all on the driver's side with that TH400 and a floor shift conversion.[img]/wwwthreads_images/icons/tongue.gif[/img] Hmmmm......I don't remember making up a 360 swap writeup. It musta been someone else.[img]/wwwthreads_images/icons/blush.gif[/img]
CJDave
A Jeep Skunkworks run by Moonguys[img]/wwwthreads_images/icons/wink.gif[/img][img]/wwwthreads_images/icons/tongue.gif[/img][img]/wwwthreads_images/icons/laugh.gif[/img], buildin' the ultimate SNOJEEP!
**DONOTDELETE** 09-24-2001 03:36 PM
I'm running Heddman headers between the frame rails. And when I say between, I mean touching the inside wall of the frame rails and nearly touchin the motor mounts and transfer case. They're really tight, which I'm not too happy about.
Not to mention, getting them in was an acrobatic display of cat-like grace, as I perched with a foot on each fender standing over the engine compartment, both hands holding up the hood and stomping on the b!tch to cram it down (even after removing the steering shaft).
Who needs a road...if there's a perfectly good JEEP trail somewhere else!?
**DONOTDELETE** 09-24-2001 06:50 PM
The rear dump manifolds seem to work fine although the clearance to the firewall is tight. The exhaust problem can be resolved by a competent muffler man. The clutch linkage shouldn't be an issue. Keep in mind though anything is possible. If you go with in-frame headers the Headmans seem to be the best for the $$$.
JpShp
http://www.jeep-shop.com
CJBEN 09-24-2001 07:04 PM
Sorry, I don't have any input about this application, but I did read the 360 swap guide article, and I do have a question. The article says if you use the tf999 tranny, you have to use framerail headers, which is fine with me, I just am trying to get everything I need ready because I will be doing this swap in the next month or so. thanks!!
86 CJ7 258, weber carb, rusty but trusty!!
done 09-24-2001 07:25 PM
CJ Dave,
Sorry about my confusuion on who to credit for the 360 Swap guide writeup. I got confused by the moonguy crew involved in the writeup. A lot of people on the BBS contributed to it. Jeeper2 posted the first one that I found and made a copy of.
