Re: Replacing Tub on YJ....!
Tub swapping isn't hard. I swapped a YJ onto my CJ frame but they are almost identical. Gut the tub, take off the hood, unbolt the fenders, remove the batery/bracket, disconnect the heater/ac lines, disconnect the fuel filler, unbolt the tub, lift off the tub with at least two people, set the tub back on the frame and disconnect all the vent lines, roll over valve, etc, that you missed; then remove the tub. You can do it in a weekend if all the bolts come out easily and how much painting/fixing you have to do on the frame or tub.
Karl
80 CJ/YJ-7 FrankenJeep
94 Grand Cherokee
