-   -   YJ runs for ten seconds (https://forums.off-road.com/jeep-short-wheelbase/88090-yj-runs-ten-seconds.html)
**DONOTDELETE** 09-22-2001 04:29 PM
I posted my problem last night and got no responses. I have high hopes this time.
My 91 YJ (4.0L/5speed/BDS lift) has run well since I bought it in March. This morning, I went to leave for work. The Jeep started normally, but stalled after about ten seconds. Three attempts to restart it were unsuccessful. I smelled gas as I got in my other truck to make it to work on time. Came home this afternoon and popped the hood to look for anything obvious. Again it started immediately and stalled after ten seconds, then wouldn't start. Same thing after an hour or so. It has a few hundred miles on an Accel coil, new fuel pump and filter, and properly gapped plugs. I have rebuilt engines in the past, but admittedly know very little about computer diagnostics and fuel injection. Any advice before I get elbow deep in it would be appreciated. Tried again today and it ran fine for 15 seconds before dying. Didn't try to restart it.
W.C. 09-22-2001 05:37 PM
Re: YJ runs for ten seconds
Check for fuel leaks(you smelled fuel), if there is a leak, you would'nt have fuel pressure. The injectors will fire the fuel that's immediately in the line closest to the injector and then starve. Check fuel pressure, the fuel line(filter, pump) may be stuck or pinched only allowing a small amount of fuel to pass by, when you turn the key, the pump starts and has a little time to pressureize the system but after the start, it starves.
Wayne @ Big Island RockCrawlers
"PYRO" The Rock Crawler
Web Site: http://www.members.tripod.com/surfmac/Index.html
**DONOTDELETE** 09-23-2001 06:13 AM
You might as well check the flywheel sensor. when dirt accumulates on it it gives faulty signals to the computer module.
Desertbuzz
