-   -   Why electric fans? (https://forums.off-road.com/jeep-short-wheelbase/88042-why-electric-fans.html)
Mel85CJ 09-25-2001 10:26 AM
Re: Why electric fans?
Jeff,
Do you know how many watts a grinder uses. We just put a dinky inverter on our '79, mainly to charge the video camera & have for things like a blender [img]/wwwthreads_images/icons/crazy.gif[/img] - I think it's only 450 watts - I was wondering if we could use a grinder with it.
-Mel
http://www.in2jeeps.com
"The only makeup I wear is never-seez"
http://www.national-lighting.com/mel3bmud.JPG
JeepDaddy 09-25-2001 11:16 AM
Electric fans have their place when a mechanical won't fit or when water is an issue.
Electrics do not pull as much air through a radiator as a mechanical fan. Their CFM rating is a best case scenario (i.e. not pulling air through a restriction such as a radiator).
A shrouded mechanical fan with a thermal clutch is the most effective cooling strategy in most situations. Think about it....an electric fan is a fan blade driven by an electric motor driven by an alternator driven by the same belt as a mechanical fan. There are some efficiency losses in the energy transfer.
The thermal clutch normally starts to slip at about 1800 RPM - Higher if the air is hot. This prevents too much power loss at higher RPM.
1976 CJ7 304/TH400/QT/D30/AMC20
Front D44 in process.
