My starting problem (updated) - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-21-2001, 09:45 PM Thread Starter
JeepnGreg's Avatar
ok still not cranking....
new solenoid
new starter
new ignition switch,
new ignition module
new battery cables
i tested continuity in the blue/green line that goes to the solenoid and it tested good from the fuse block area to the solenoid, but im still not getting volts there when i crank.
so that leads me to believe that the bad wiring much be behind the dash somewhere.....
oh well...i'll keep you posted....i'll carry jumper cables so i can jump the starter every time i want to drive my jeep
<font color=red>Jeep'n Greg</font color=red>
1985 CJ7 in pieces right now
JeepnGreg is offline
post #2 of (permalink) Old 09-21-2001, 10:43 PM
Re: My starting problem (updated)
one wire coming from the ignition switch should have +12 when the key is in the start position.
check it at the switch, at BOTH sides of the plastic connector at the base fo the column.
if its bad replace the wire, My guess is the conductor is pushed back into the plastic connector ( or carbon fouled)
OzarkJeep
I love the U.S.A.
ozarkjeep is offline
post #3 of (permalink) Old 09-21-2001, 11:25 PM
Start at the solenoid and work back to the ignition switch. Use a screw driver to short between the hot lead and the small ignition wire terminal on the solenoid. It should crank. If not, check all wiring and make sure the solenoid is grounded properly.
If you use two screwdrivers to short between the hot lead and the starter lead on the solenoid, it should crank.
To sum it up, start bypassing components until you find the problem.
Keep the faith and a cool head and you will find the problem.
1976 CJ7 304/TH400/QT/D30/AMC20
Front D44 in process.
JeepDaddy is offline
