Need Tire Help - 31" - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-20-2001, 11:32 AM Thread Starter
Need Tire Help - 31\"
OK. Give it to me straight gang, 97 TJ, stock height, currently with 215s, How will 31 x 10.5" BFG ATs look on the Canyon rims?
Are they gonna be "big enough?"
If anybody has pictures of this setup, i'd love to see them!!
Thanks!
BillTJ
billTJ is offline
post #2 of (permalink) Old 09-20-2001, 12:32 PM
Re: Need Tire Help - 31\"
IMHO - it will look good. Bound to be an improvement over the 215s (about 27" dia) on it now.
Big enough? That is your call not mine or anyone elses'...
larger tires will bring other points to ponder - rubbing and gearing are the two biggest
Tell what engine, transmission & gears this Jeep has plus what is your intended use. You will get more opinions about what is best setup than you can find what to do with.
My exp with a 2.5L 5spd TJ and 31s - retained good street manners (except the bias-ply thing but I accepted that). it could go most but not all places my friend's w/bigger Jeeps went off road (I accepted that too) - even better off road after adding 2" spacer lift. when parked next to a friend's TJ w/33s and 3" of lift mine looked tiny. I liked it just fine. I was sad to sell it.
Here's a pic. I know it is not Canyon rims... but it is best I can do.
trailisman is offline
post #3 of (permalink) Old 09-20-2001, 01:19 PM Thread Starter
Thanks for the reply! The Jeep is a 5 speed 4.0, intended use: daily driver, snow, sand, cross country trails, eastern US terrain, no slickrock or desert type stuff at my immediate disposal.
bill
billTJ is offline
post #4 of (permalink) Old 09-20-2001, 08:22 PM
31's look and work great on factory 8 inch wheels, but you will have to adjust the steering stops or else you'll get tire rub on the lower control arms. On the back of each hub/spindle assembly, you'll see a bolt with a jam nut welded to it. You can easily see these bolts looking under your Jeep from the front. Remove the bolts and add a couple of washers and replace the bolts. Check to see if there is still any rubbing. If so, add more washers. You may need anywhere from one to five washers per side, depending on how wide the tires are and how thick the washers are. Each side will probably be different. On my 97 TJ with 31 inch BFGoodrich Mud TA's, I only needed two or three per side.
I also added 3/4 inch front coil spring spacers to give the front tires a little more room to flex, and level my Jeep out a little, since the front sits a little lower then the rear. Now it really looks sharp! Not to mention much better traction then the factory tires.
"It's a Jeep thing... and I DO understand"
my97TJ is offline
