-   -   Anyone run or broke a WC T-5 (https://forums.off-road.com/jeep-short-wheelbase/87759-anyone-run-broke-wc-t-5-a.html)
**DONOTDELETE** 09-19-2001 08:53 PM
Well I finally broke the rest of the teeth off the reverse idler and counter shaft in my non world class T-5. I am considering getting a WC T-5 since it is a direct bolt in. My question is how strong are they. If I broke the reverse gear in one year on the NWC what chance will a WC stand.
Was this replacement a direct install as advertised or was more work need.
Has anyone broke a WC T-5 and what broke.
thanks,
bandhmo
**DONOTDELETE** 09-20-2001 03:04 AM
Re: Anyone run or broke a WC T-5
The World Class T-5 has improved bearings, output shaft, and organic synchros. I don't know about the gear sets though.
Tourqe rating is 300ft/lb. Up I think from 220ft/lb for the T5.
I don't know about the direct replacement issue, but I guess the ones offerred by Advanced Adapters would be.
Back when I was considerring swapping one in place of a T4 the output shaft needed changing when the tranny came from a Mustang or Camaro. Advanced wasn't suplying complete WC T-5s then.
My take is it would be a modest improvement in reliability.
I put a strong running 350 in my jeep, so I bit the bullet and went for the NV4500. Had I been running the 6 cyl. I would have been willing to try the WC T-5.
Wish I could offer you more first hand experience.
'85 Scrambler under construction
5.7L Vortec, NV4500, and god knows what.
**DONOTDELETE** 09-20-2001 04:59 PM
Thanks PsychoJeeper, I would like a bolt in replacement due to lack of tools for fabrication or I would look into the NV4500. Sadly that is not an option right now.
Has anyone run one or more importently Broke a WC T-5. Any info or experiences would be a great help.
bandhmo
**DONOTDELETE** 09-21-2001 03:11 PM
I know others are running this setup. any impressions would be great.
bandhmo
RickB 09-21-2001 03:24 PM
I don't have a WC T5, but from what I read from previous posts, they are alot stronger than the T5. They are a bolt in swap. Do a search for "WC T5" and see what you come up with. I just did a search and this is what was posted.
Rick
80 CJ7
Bob Ackley 09-21-2001 04:17 PM
I have had one for about 5 years now behind a mildly warmed up 6 cylinder. I run 33" Swampers and have 4.27 gears and ARB's in both ends. It has performed quite well with no problems. I too couldn't afford a NV4500, and the WC T-5 is perfect for my application.
http://bbs.off-road.com/wwwthreads_u...-signature.jpg
Bob in Ma.
Raduckal 09-21-2001 09:50 PM
I run an AA WC T-4 behind a 258. So far I've had no problems. It was a bolt in swap for a SR-4 and is a perfect match to a T-4 or T-5. I did have to get the big clutch cover assembly. Some jeeps have 10.5" clutch. AA sends a 11" disc. It shifts so smooth, more like a car.
I'm on here so much, I have carpal tunnel reader syndrone.
**DONOTDELETE** 09-23-2001 12:12 AM
As for the direct replacement issue:
You should contact Advanced Adapters. If I remember right, a WC T-5 from a Ford Mustang would bolt to a Jeep bellhousing, and you could get an kit from A.A. to adapt it to a Dana 300.
The WC T-5 to Dana 300 kit ran about $495 or so.
Or you could just get the whole tranny ready to go from them.
Bob Ackley 09-23-2001 10:01 AM
Even *IF* you could somehow put in a Mustang T-5 by doing major tailshaft mods, you would still be stuck with using the crappy 1st gear ratio of about 3:1
Bob in Ma.
