Re: lowering the radiator
Hey, i agree with them, dont get the 3 inch unless really necissarry, i just did it though, haha. It is really ugly too. About the steering shaft, i dont knwo hwo it is for yours but mine there were 2 nylon pins i drilled out and it is supposed to extend, i had to pound on mine for a while for it to drop. Lowering the radiator is so your fan still pulls air through the radiator. I did not do this but believe it would be easiest this way, just take the whole radiator out and drill new holes to lower the radiator(this was the biggest pain trying to keep it in the jeep, took me a few hours). Also, about the fan shroud, you may have to lower that more than teh radiator is lowered and i still had to cut out the bottom of the fan shroud, try not to do that if possible. Um, the shifter, i did not have to cut out the floor where the shifter is. If your jeep is manual, i had to extend the clutch linkage(welding) and i also had to lower the hole through the firewall where the linkage goes through. I believe that is all i did. When you raise up the body, before you put in the pucks and everything, make sure nothing is being streched. Have fun, be safe. Peace
Andrew
Im good at being a Lil8itch, so im sticking to it!
C/O BBS Chat Room
