- Jeep-Short Wheelbase
- - quadratrac axles from wagoneer
(https://forums.off-road.com/jeep-short-wheelbase/87710-quadratrac-axles-wagoneer.html)
Just found a pair of axles locally from a 77 Wagoneer with quadratrac. Are these desirable axles to swap into my 80 CJ7 with a 258, T176 and d300? Or are they offset diff's like the CJ quadratracs?
Rick 80 CJ7 |
Re: quadratrac axles from wagoneer
The rear would be an offset AMC 20. The front should be OK if you shorten it.
1976 CJ7 304/TH400/QT/D30/AMC20 Front D44 in process. |
The quadratrac wagoneers came with an offset dana 44 rear. It is offset too much for a centered output transfer case in a CJ but it lines up perfect for a quadratrac or dana 18 in a CJ. I have a dana 44 from a quadratrac wagoneer that I swapped behind my quadratrac and it lines up perfect.
User Alert System provided by
Advanced User Tagging (Pro) -
vBSecurity v2.2.2 (Pro) -
