DuraSpark Module test
Does anyone have the procedure for testing the Duraspark module that is used in the early Wranglers, I was running my Jeep tonight and it shut off again. I have tested everything else (see HOT resistance wire post) and now I am starting to thing the module is messed up. My FSM has a procedure for testing this but it is using connector on the MCU which I dont have anymore since the Team Rush Upgrade. Also, is there an application that I can get the module from that would be cheaper then getting it for a wrangler, the Pep Boys near here wants $70 for it. Thanks for your help.
Kris
I do the same thing every weekend, its just the location where I do it that changes!
