No start !!! HELLLPP !!!!!!!! anyone????!!!!!!!! - Page 2 - Off-Road Forums & Discussion Groups
post #11 of (permalink) Old 09-17-2001, 04:51 PM
sheesley
Re: No start !!! HELLLPP !!!!!!!! anyone????!!!!!!!!
check your posts, and the make sure you have a solid ground.
--->"Some people go through life thinking they hit a triple: But they were actually born on third base."
post #12 of (permalink) Old 09-17-2001, 05:05 PM
1. Remove the solenoid.
If it's good, then there's a wiring error, or a bad wire or ground.
2. Have the autoparts store test it.
3. Remove the Starter.
If it's good, the problem is in the ignition swtich, or wiring harness or the battery/starter cables.
4. Have the autoparts store test it.
5. Leave the ingition module in place for now, it won't prevent cranking.
6. Examine, or replace the battery cables.
Let us know what you find.
post #13 of (permalink) Old 09-18-2001, 04:39 PM Thread Starter
JeepnGreg's Avatar
new ignition switch and still nothing....im taking my ignition module to be tested tomarrow....if thats not it, then that only leaves the possibility of bad wires.
im going to throw this jeep off a cliff...grrrrrrrrr
<font color=red>Jeep'n Greg</font color=red>
1985 CJ7 in pieces right now
JeepnGreg is offline
post #14 of (permalink) Old 09-19-2001, 08:24 AM
the starter solenoid went out on my 81 cj-7 a few years ago and i had a similar problem. the new solenoid i purchased was a universal fit style and the posts were in a different order. i ended up having to cut the little rubber pieces that hold the wires together so i could switch them ( i think). i will look at it tonight and reply tomorrow as to what i did exactly, and maybe have some pics. matt
jeepnmatt is offline
post #15 of (permalink) Old 09-22-2001, 02:23 PM
Get it yet? No luck here..
post #16 of (permalink) Old 09-22-2001, 02:23 PM
post #17 of (permalink) Old 09-22-2001, 08:17 PM Thread Starter
JeepnGreg's Avatar
still no luck bud.
i will try a few more times then take it to a shop
post #18 of (permalink) Old 09-22-2001, 09:45 PM
Be sure all your connections are tight and clean ,as CJDave is prone to say make sure all your grounds are well connected,
I had a simular problem once and it was the wire going from my alternator to the in dash ampmeter,since the wires are so thick ,while probing around under the dash for a different problem I loosened the connections by accident.thus it would not start.I also replaced starter ,solenoid and checked everything else ,drove me nuts till I found it .
I also fried a lighter ground wire once when the main ground going to the starter mounting bolt loosened up and fed all the curent through the lighter wire ,burned it right in half.sceared the crap out of me seeing all that smoke come from under the hood .
Ray
unhumen is offline
post #19 of (permalink) Old 09-23-2001, 11:16 PM
Novice
had a similar problem and on mine it was a relay
snatch1 is offline
