T-18 / skidplate question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-12-2001, 09:02 PM
Dunckelman
When you install a T-18/D-20 in a 79 CJ-5 do you need to modify the skidplate? I am off about a 1/2 to 1 inch lining up the skidpate to the back tapped holes in the frame? Could I have another problem (engine mounts, tran. mount placement)? I thought this would bolt up without modification. The setup came out of a 79 CJ-7. Any thoughts would be appreciated.
post #2 of (permalink) Old 09-12-2001, 09:50 PM
ricochet's Avatar
Re: T-18 / skidplate question
I did the same exact swap. My skid plate lined up with the back holes, but I had to cut new hole in the skid plate for the tranny mounts which were custom too.
Keith
ITS GOOD ENOUGH [img]/wwwthreads_images/icons/wink.gif[/img]
http://www.dreamwater.com/ironpines
ricochet is offline
post #3 of (permalink) Old 09-12-2001, 10:16 PM
Pooh-Bah
pbmcauliffe's Avatar
As above, mine lined up with the rear set of holes, but had to drill new holes for the tranny mount bolts.
<font color=blue>pbm</font color=blue>
<font color=red>Knowledge is Power, but Ignorance isn't always Bliss!</font color=red>
pbmcauliffe is offline
post #4 of (permalink) Old 09-13-2001, 08:59 AM
Dunckelman
When you said to drill new holes - would I just slot the existing holes? Or actually drill new holes? It looks like you would end up on the side wall (on an angle - not on a flat surface) of the cavity in the skidplate? Should I just use longer bolts and fender washers to compensate?
post #5 of (permalink) Old 09-13-2001, 09:49 AM
I left my skidplate in the stock location...and took a torch to the big "hump" in front, cutting it out...I then made a new tranny mount for the t-18. However, lately, I've built a new tranny crossmember and skidplate...and I think that's a much better expenditure of time and effort than trying to fix the existing skidplate.
I Jeep, therefore I am.
post #6 of (permalink) Old 09-13-2001, 10:50 AM
Pooh-Bah
Yes you can slot them and use bigger washers, that is what I did, I drilled another hole, then cut out the middles so it was easier to get them to all line up, then big washers.
