I Do This For The Glory
Re: Used ring & pinion, is it worth it?
What's you gear ratio now? The carrier break on the D30 front axle is 2.73 to 3.54 and 3.73 to 5.38. So if you have 3.54 and down gears now, you'll need a new carrier for the front. The rear should be OK unless you're running 2.73's, and then you'll need a new carrier for the rear as well.
JEEPN
Winter Harbor, Maine
'88.5 Zuki, 7" Lift, Locked, Swamped, Rolled, and just generally broken in right!
