Re: Jeep Starts but wont run!
Good starts form the other two responces. There is also a ballast resister between the ignition swich 'run' position and the coil, it could be an actual resister, or a resistance wire. If there is no voltage avaiable at the coil when the key is just at 'run' start working your way back until you find voltage. Good luck, Scott
My Rides
1979 CJ-7: 304, 3spd, much is my rebuild
1983 CJ-7: 258, 5spd, for Peru Excursion
1989 XJ: has seen every state except Hawaii
In search of lost paths and distant locations...
