Re: I want a spool
My spool didn't need to be reset. although you will need a press to get the bearings off and on the spool.
If your looking for a cheap spool, their avg of 150-200
you can get a cheaper one though, through lincoln, they can be as cheap as 10$, if you have a friend that knows how to set it up for you. Just clean your carrier out of gear oil, and weld it up. It will give you the same effect, and 1/2 the work.
JR
"Some People Live An Entire Lifetime And Wonder If They Have Ever Made A Difference, But The Marines Don't Have That Problem" R. Regan
