- Jeep-Short Wheelbase
- - Broke oem locking hub - replacement?
(https://forums.off-road.com/jeep-short-wheelbase/86390-broke-oem-locking-hub-replacement.html)
Just realized that the oem lockng hub on my 84 cj7 with dana 30 front end is cracked right at a bolt hole. Anyone have a suggestion for what to replace it with? Are some locking hubs better than others?
Tim 84 CJ7, 258, HEI, M/C 2100 carb, 5 inch lift, RS9000's, 33x12.5 BFG M/T's, 4.56's and Detroit softlocker, full cage & belts, Xenon flares, Dana 44 rear, GM dual diaphragm brake booster |
Re: Broke oem locking hub - replacement?
Warn makes replacement hubs for the "5 bolt" ones that are on your CJ.They are probably a bit better than the stock ones. Otherwise you can convert to the early "6 bolt" Warn Premium hubs, but this requires the actual "Hub" and lockouts from a '81 (I think) or earlier CJ, or you can spend some cash and buy the conversion new from Warn for about $275. Check out 4 Wheel Drive Hardware http://www.4wd.com. if you don't already have one of their catalogs, go to the web page and request one...it's free!
Mike H. 1983 CJ-7 Laredo,It's Orange! Now I just have to put it all back together. |
User Alert System provided by
Advanced User Tagging (Pro) -
vBSecurity v2.2.2 (Pro) -
