I Do This For The Glory
Re: SOA Scout 44 front?
You must be registering it as an antique to get away from the inspection?
Yes, you'll have to grind into the pumpkin to make the perch for the SOA.
I'm doing a SOA for Archie's CJ next weekend after the club meeting, but using the D30 front and a Scout rear. How are you going to setup the steering? The Willys has a Ross system and the Scout a Saginaw, and with the open frame of the Willys, along with it being thin walled, you might run into problems.
Where did you have the axle cut down, I'm looking to have the same thing done to one of mine for a Swap.
JEEPN
Winter Harbor, Maine
'88.5 Zuki, 7" Lift, Locked, Swamped, Rolled, and just generally broken in right!
