Re: Dana 44 axle flange
It shouldn't compromise the strength if the bolt pattern is not any larger and closer to the edge of the flange. That kind of stuff is fairly standard fare for a machine shop to do. Gotta be cheaper than buying custom axles.
Tim
84 CJ7, 258, HEI, M/C 2100 carb, 5 inch lift, RS9000's, 33x12.5 BFG M/T's, 4.56's and Detroit softlocker, full cage & belts, Xenon flares, Dana 44 rear, GM dual diaphragm brake booster
