F-Head oil pump - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-06-2001, 11:05 AM Thread Starter
F-Head oil pump
Does anyone know of any problems with the Federal Mogul oil pumps for F-Head motors. The pump is designed differently with 2 gears vs. stock impeller type? Iíve just started the new motor and I don't have any oil pressure. The 2 plug are installed inside the block, 2 end plugs and the timing gear nozzle. I removed the oil filter and with the motor running I only get little sperts of oil. I'm hoping that the design change of the pump may be the problem or just a bad pump.
78 CJ7 304V8 Fully locked. Got Rocks?
WallyCJ7 is offline
post #2 of (permalink) Old 09-06-2001, 12:52 PM
Re: F-Head oil pump
Hi,
First of all, the oil filter in an F-head is the bypass type and it only filters some of the oil. I'm not sure how much flow you are supposed to see. Also, there are some differant lenght bolts you are supposed to use for the federal mogul pump. Second, a better resource for F-heads is WillysTech
There is also good stuff at The CJ3b page
I hope this helps...
Josiah
Hillsboro, OR
1955 Willys CJ5 Buick 225 V6 160HP 270ft-lbs, T90 trans, Warn OD, PTO winch, Spicer 18 T Case, RS9000's, Dana 25F/ 44R,
5.38:1 gears, 11" brakes, Bestop Supertop, Hurculiner
post #3 of (permalink) Old 09-06-2001, 12:57 PM
Re: F-Head oil pump
Did you prime the pump?
Andytron is offline
