- Jeep-Short Wheelbase
- - F-Head oil pump
(https://forums.off-road.com/jeep-short-wheelbase/86039-f-head-oil-pump.html)
F-Head oil pump
Does anyone know of any problems with the Federal Mogul oil pumps for F-Head motors. The pump is designed differently with 2 gears vs. stock impeller type? I’ve just started the new motor and I don't have any oil pressure. The 2 plug are installed inside the block, 2 end plugs and the timing gear nozzle. I removed the oil filter and with the motor running I only get little sperts of oil. I'm hoping that the design change of the pump may be the problem or just a bad pump.
78 CJ7 304V8 Fully locked. Got Rocks? |
Re: F-Head oil pump
Hi,
First of all, the oil filter in an F-head is the bypass type and it only filters some of the oil. I'm not sure how much flow you are supposed to see. Also, there are some differant lenght bolts you are supposed to use for the federal mogul pump. Second, a better resource for F-heads is WillysTech There is also good stuff at The CJ3b page I hope this helps... Josiah Hillsboro, OR 1955 Willys CJ5 Buick 225 V6 160HP 270ft-lbs, T90 trans, Warn OD, PTO winch, Spicer 18 T Case, RS9000's, Dana 25F/ 44R, 5.38:1 gears, 11" brakes, Bestop Supertop, Hurculiner |
Re: F-Head oil pump
Did you prime the pump?
User Alert System provided by
Advanced User Tagging (Pro) -
vBSecurity v2.2.2 (Pro) -
