Flywheel and clutch compatability - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-06-2001, 06:58 AM Thread Starter
I have an '87 YJ with a 258 and the peugot garbage tranny. The tranny is shot and I've located an NV3550 with extremely low mileage for a great price. Anyway, the guy has all the parts for it including the flywheel and clutch. My question is, will the flywheel bolt up to my engine and if it will, will the clutch work or will i have to get a new one? The tranny is coming out of a 2001 TJ. Thanks again for all the help.
Donny
1987 YJ 258 I6, 5 Speed, TFI Upgrade, MSD 6A, TFX Exhaust, Smitty Sure Steps, Howell Fuel Injection1999 Cherokee Sport, Stock
donnyg is offline
post #2 of (permalink) Old 09-06-2001, 10:16 PM Thread Starter
Re: Flywheel and clutch compatability
donnyg is offline
post #3 of (permalink) Old 09-06-2001, 11:48 PM
jeeperjohn's Avatar
The flywheel should bolt up. The 2001 flywheel may be thinner (Crank side of crank flange to clutch disc surface), so measure the thickness (from the crank to the clutch disk surface) of both flywheels and compare were the starter ring gears are on the flywheels. You also need to compare the starters as they will be different it the flywheels are not the same. I don't know the input spline count or diameter for the nv3550, but the peugot (push-go?)garbage tranny uses a 1 1/8 inch 10 spline clutch disk. If you can get it grab the metal plate that goes between the tranny and the block. The best thing is to just compare the two. I wasted a day and pulled and replaced my np435 because of bad info (from AA and a couple of other sources) on the proper combination of parts for the my clutch and it was only because I took a look at starters from an '83ish CJ and the 88YJ that I started asking questions about flywheel thickness. So ask all the questions, reask and then compare parts to find out for sure.
They that can give up essential
liberty to obtain a little temporary
safety deserve neither liberty nor safety.
jeeperjohn is offline
