Extended Wheelbase - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-06-2001, 12:15 AM
Extended Wheelbase
What would you consider the pros and cons of extending the wheelbase on a cj5?
Thanks Miles
"When in doubt go faster"
'64 CJ5, 351W, T-18
post #2 of (permalink) Old 09-06-2001, 12:58 AM
Re: Extended Wheelbase
well if you are asking me you are asking the right person. i've done it. i cut my jeep in half and lengthened it to a 100" wheelbase. here you go
pro's
stabilitly, more room (depending on how you lengthen it), better on hills, better on climbing ledges, did i mention it is alot more stable!? longer rear d/shaft. more room for mufflers, track bars etc under there, etc.
con's
not as small of a turning radius, more sheet metal to ding (depending on how you do it).
i love my 100" wheelbase ALOT more than i did the stock one. it is alot more capable and less roll happy ( i sya that but i only layed it over when it was stock and i have rolled it completely since i have lengthened it). if i had it to do over io wouldn't lengthen the body but rather cut the rear of the back fenders out and slide the rear back. why? well like i saidd i have more sheet metal to ding and now with a rolled body i would have to buy another tub and then cut and lengthen it and i'm just not going to do it. i will run it like it is until i decide to build something else. this might not be an issue for youe if you don't wheel hard like i do. if you are just looking for more room the cut and lengthening is a good thing.
brian wilson
80 cj5 "high 5"
stretched to 100" wb
vortec350/4L80E/d300/d60fr/14br/detroits/4.56/38's
post #3 of (permalink) Old 09-06-2001, 01:42 AM
What Brian said on Pros & Cons
I used the stock length frame, moved the front axle forward 4.5" with Alcan 50" SOA springs and moved the rear axle 5" back with 1/4 ellip springs and 4 link. Its very stable with the longer wheelbase(93"), 7"lift and fullwidth fullsize axles.
Alot of the top ARCA guy are running about 94" to 96" wheelbase.
Wayne @ Big Island RockCrawlers
"PYRO" The Rock Crawler
Web Site: http://www.members.tripod.com/surfmac/Index.html
W.C. is offline
post #4 of (permalink) Old 09-06-2001, 07:26 PM
Another con to add: Less brak eover angle. Might be a problem on hard trails unless you have some serious lift.
A.B.
I think, therefore I am ...... a Jeeper
http://www.ShortWheelbase.com
post #5 of (permalink) Old 09-06-2001, 09:03 PM
true on the break over angle. i thought of that but when i actually went to typing i didn't add it to my list. i run 38.5 sx's and it isn't too bad and it actually wasn't too much of a problem with the 35's i used to run after i tucked the tranny/x-case up higher into the frame rails.
brian wilson
80 cj5 "high 5"
post #6 of (permalink) Old 09-07-2001, 01:57 AM
Thanks for the help. 100" takes you right past a cj7 in wheelbase. Why not just start with one of those??
More info on those Alcon SOA springs and your 1/4 elliptical would be great. How stable is that set up at highway speeds??
Brian, where did you lengthen the tub?
Thanks Miles
'64 CJ5, 351W, T-18
post #7 of (permalink) Old 09-07-2001, 02:42 AM
There is more on my suspension on my site, just click below, Its very stable on the highway with a little body roll in tight corners. It's the best setup I've used, so far.
BTW, Some wheelbase info,
Pre '72 CJ5s - 81",
Post '72 CJ5s - 83.5",
CJ6 - 101",
CJ7 - 93.5,
CJ8 - 103.5
W.C. is offline
post #8 of (permalink) Old 09-07-2001, 02:45 AM
Post deleted by W.C.
W.C. is offline
post #9 of (permalink) Old 09-07-2001, 06:43 AM
w.c. ,
could you please repeat that. i didn't quite get it the first time!lol!
brian wilson
80 cj5 "high 5"
post #10 of (permalink) Old 09-07-2001, 07:10 AM
Whats the wheelbase of a stock Scrambler????, oh wait a minute, I think I saw a post in this thread with the weheelbase numbers, now if I can just find it,,,hmmmm. LOL, I think wc got his point across....[img]/wwwthreads_images/icons/smile.gif[/img]
http://bastroptx4x4.alloffroad.com
kerryp is offline
