Which tires? (was: Pirelli tires) - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-05-2001, 04:20 PM Thread Starter
Does anyone run Pirelli Scorpian A/T's on a Jeep? I'm due for a new set of tires and did some shopping today. They're only $115 each for 33/12.50/15 and have a 40,000Mi warranty. I know a guy that's got a little bit smaller ones on a Zuk and I really like them - they're quiet and wear good on the road and do pretty good off-road, just wanted to get more opinions before I buy.
-Derek Schwab
'97 Sidekick Sport
'83 CJ-7
dschwab9 is offline
post #2 of (permalink) Old 09-05-2001, 06:01 PM
Re: Pirelli tires
Pirelli is replacing them with a new tire, the ST, because they had so many warranty issues with the AT. The AT's are loud, hard, and wear really unevenly. That, and they suck at traction, as well. If you want a 33x12.5 for that price, look at firestone, dunlop, or cooper for better tires.
Moneyless, Will weld for jeep accessories.
post #3 of (permalink) Old 09-05-2001, 06:37 PM
sas87yj
Re: Pirelli tires
DON'T do it!
spend a little more for some good shoes. get some BFG's or GOODYEAR's
post #4 of (permalink) Old 09-06-2001, 12:13 AM Thread Starter
Re: Pirelli tires
I didn't realize buying tires would be this complicated [img]/wwwthreads_images/icons/smile.gif[/img] Guess I'll go shopping again tomorrow. What about the firestone Wilderness A/T III? Does anybody run those? the seem to be fairly cheap with a good warranty (50K I think)
Someone mentioned GoodYear. What Goodyear tire should I be looking at? They have so many, it's really hard to pick one.
It's got BFG A/T's on there now, and I don't like them. There's about 1/8" of tread left and the still make a ton of noise and they're cracking really bad.
-Derek Schwab
'97 Sidekick Sport
'83 CJ-7
dschwab9 is offline
post #5 of (permalink) Old 09-06-2001, 12:21 AM
Smokngun's Avatar
Re: Pirelli tires
Wow, If BFG A/T's make too much noise for you then I don't know what to tell you. What do you mainly use your Jeep for? What type of off roading do you do? Generally, the higher a mileage warranty a tire has, the harder it is, meaning it will probably handle a bit worse in the rain. I've used BFG A/T's on everything I've owned as daily driver/all around tires and I've loved them. I have my first set of BFG Mud Terrains on my CJ and cant wait to test them out!
Mike H.
1983 CJ-7 Laredo,It's Orange! Now I just have to put it all back together.
Smokngun is offline
post #6 of (permalink) Old 09-06-2001, 12:38 AM Thread Starter
I think the noise is due to the fact that it's way out of alignment and either the caster or camber is off (forget which is which) and the tires are worn really weird. But seriously - they're louder than a lot of mud tires. if it's usually a quiet tire - it's probably related to something else. What really concerns me is the number of cracks (not just in the tread- in the sidewalls too). Anyone else had them crack?
What do I use my Jeep for? It's not a daily driver - but it does spend a lot of time on the road. It's not a trailer queen - it gets driven to the trails and I drive it to work at least once a week. Most of my wheelin' is in the mountains - mostly rocks & stream crossing and stuff.
I guess the real question is What can I get for less than $150 that well perform well off road, and not wear out real fast on the road?
Maybe I'm asking for too much and need to spend a little more cash. What do you guys think?
-Derek Schwab
'97 Sidekick Sport
'83 CJ-7
dschwab9 is offline
post #7 of (permalink) Old 09-06-2001, 06:32 AM
sas87yj
Re: Which tires? (was: Pirelli tires)
well you should spend your max budget of $150 and get the BFG MT's or a little more and get the GOODYEAR MTR's. they are both noisy of course but then hey you are off-roading! if your alignment is ON, they will wear even. i had some 235 firestone ATX when i bought mine, then they were re-called and i went to 30" goodyear AT's and now have 32" goodyear MTR's. well no i'm not done yet! i'm sure 35's are in the cards. i've got 6000 miles on the mtr's and wear great. hey a good HOWL on the highway is MUSIC to my ears!!!!!!!!!!!!!!!
post #8 of (permalink) Old 09-06-2001, 07:39 AM
Smokngun's Avatar
The BFG A/T's really are a quiet tire (comparitavely) and should do well for the mix of driving you do. The cracks are due to age and/or too much heat. If your alignment is way out of whach, then there is where the heat came from. How old are the tires? I've worn them out in 40,000 miles/ 3-4 years, and they just started developing cracks between the tread blocks (small ones are common). Good luck in your decision!
Mike H.
Smokngun is offline
post #9 of (permalink) Old 09-06-2001, 09:58 AM
BFG ATs are a good tire...but they do seem to be prone to wearing really unevenly, even when alignment and balancing problems are only slight. If you really want a quiet tire that will be nice on road, have a 50K warranty, will wear even, and will not be totally helpless off-road, I'd suggest taking a look at the Michelin XCX APT. Try a Sears somewhere around you...when they go on sale, they're very reasonable. They wear like iron, are very quiet, have good traction (not as good off-road as a BFG AT, but better on-road), and are a good all-around durable tire.
post #10 of (permalink) Old 09-06-2001, 02:16 PM
I know there are some Cooper tire people on this board, but this past weekend I heard some comments from a guy that manages a string of tire stores. They no longer handle Cooper tires. They have hardly ever seen a set wear out. They usually replace them way before there time due to broken body cords making the tires unbalencable. We never discussed any specific style or size of tire, he just claimed they broke apart in the carcas and would not balance.
This is just for information, use it as you like!
Enjoying Montana's Big Sky
jfralph is offline
