I probably know the answer - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-05-2001, 02:30 PM Thread Starter
Mel85CJ's Avatar
Will a Lockrite locker from a 1986 44 rear axle work on a Wagoneer 44 front axle? I think it should, but just double checking.
-Mel
http://www.in2jeeps.com
"The only makeup I wear is never-seez"
Mel85CJ is offline
post #2 of (permalink) Old 09-05-2001, 02:44 PM
Re: I probably know the answer
Yes, if they both have the same spline axles. BUT, that I am not sure about. I thought the fronts had 27 splines while the rears had 30. Maybe someone else can say for sure.......
Shannon
'78 CJ-5
"I'm pull'n for ya, we're all in this together."-Red Green
post #3 of (permalink) Old 09-05-2001, 02:48 PM
Yeah, Mel it will fit. A 44 is a 44, unless it is a reverse rotation, in which case the Ring and Pinion are different. There is a carrier break on the D44, but that wouldnt affect your lockright application.
Jeff
89 YJ
Adversity is imminent, versatility is mandatory, misery is optional.
H8monday is offline
post #4 of (permalink) Old 09-05-2001, 04:54 PM
Is it the GW axle with the front disconnect system? If so you might have a problem. I have heard of the diconnect system that is intergrated into the diff housing making locker installs impossible.
But there has to be a way around it as well. Here is what I am thinking...weld the front disconnect together and put some hubs inplace of the slugs. Regular axle then, unless that disconnect system is more troublesome and intrusive than I think.
Jason
[]llll[] '90 YJ & '88 Grand Waggie
post #5 of (permalink) Old 09-06-2001, 06:38 AM
I Do This For The Glory
JEEPN's Avatar
Like they mentioned before, it will fit. I scored a mini-spool for the Scout rear cheap, came from the front of a Chevy truck. As long as they're after 1970, they have 30 splines and 1.31" in diameter.
JEEPN
Winter Harbor, Maine
'88.5 Zuki, 7" Lift, Locked, Swamped, Rolled, and just generally broken in right!
JEEPN is offline
